rear window ?
Old Apr 13, 2004 | 03:34 AM
vuk75's Avatar
rear window ?
Slider window has been broke out , I just recieved a used window from my locl ford buddy free!!!!! and Im seeing that the slider bracket can be taken apart . Is there an easy way to pop the old window out far enough to put the slider in or do i have to pull the whole thing out?
99 5.4 4x4 Off road
Old Apr 26, 2004 | 03:53 AM
gpaje's Avatar
I'm think you have to remove the whole thing but not sure about it.
Here is a thread where they go into detail on how to fix a leaking rear slider, and goes in detail on the removal of the unit.
https://www.f150online.com/forums/sh...ng+rear+slider
Old Apr 26, 2004 | 10:42 AM
Rockpick's Avatar
Moderator &
I'd recommend pulling the whole thing out so that you can make sure you get the seal back in properly. Further, I doubt it'd be possible as the window is mounted on the posts that I mentioned in my post (cited above). I don't think you'd be able to 'half-way' push it out as it has to come straight back and out.
RP
