Tailgate locks itself!
Old Sep 2, 2000 | 02:35 AM
onemilmhz's Avatar
Exclamation Tailgate locks itself!
I know it sounds strange but it's true. After opening and closing it a couple times the locking mechanism engages itself. It also does this when traveling over bumpy terrain. Best I can figure is that there's something loose in there. The key works fine but I'm worried that it might not the next time. How hard is it to get inside to troubleshoot it? Any ideas what might be causing this? Anyone else have the same experience? Enjoy the holiday weekend!
Stock Stuff:
Y2K SCab 4X4, Chesnut Metallic, 5.4L, 3.55 Limited Slip, Skid Plates, Factory AM/FM/CD, 40/60 Split Bench, Sliding Rear Window, Towing Package and Keyless Entry.
Extras so far:
305/70X16 GY Wrangler ATS on American Eagle Series 146 chrome wheels, K&N air filter, Catch-All floor mats, tinted windows to match factory rear glass, Bull Ring retractable tie-downs, www.f150online.com sticker below center brake light. University of Georgia hitch cover "GO DAWGS!"
Future plans (the good stuff):
Airbox/FIPK mod, Flowmaster 40 Series muffler and stainless exaust tip, spray in liner (or Herculiner haven't decided), stainless nerf bars, hood deflector, and a Blaupunkt audio system to name a few.
Old Sep 2, 2000 | 09:32 AM
Bubbadewsky's Avatar
Post
It is very easy to get to just remove the steel inspection cover at the top of the tailgate held inplace by 8 torx head bolts. You will be able to see the lock mechanism and inside of the tailgate handle, both are held inplace by 2 bolts, remove these bolts and you will notice a spring retainer that fits in a slot on the lock, this my need a little more spring tension to keep the lock from moving on its own
2000 F-150, XLT, SC, 5.4, 4X4, 355 LS, ORP, Black/Silver, class III, single CD, sliding glass, med. gray, keyless, elect. shift, engine date 8-18-99, Superchip. '93 Harley Fatboy Black & tons of chrome
Old Sep 2, 2000 | 10:03 AM
2001SUPERCREW's Avatar
Post
HI
THIS HAS HAPPED TO US AS WELL?? FELT STUPID
TELLING THE DEALER TOOK THEM 2 TIMES TO FIX IT
1999 150 XLT LOADED
Old Sep 2, 2000 | 06:38 PM
MOVEOVER's Avatar
Post
I wish mine would lock itself! I always forget.
Old Sep 6, 2000 | 10:07 AM
MNFORD99's Avatar
Cool
Hey there, mine tailgate doesn't lock itself, but after putting it up, it is a bear to get down agian, seems like there is something sticking or something like that. I actually wonder if I haven't twisted the box a little bit from offroading with it, and that has caused the tailgate to be hard to open....seems like it is locked though, everyone has a hard time opening it the first time, until I tell them to just give it a hard yank and then it opens..
Old Sep 6, 2000 | 10:55 AM
michael_hovis's Avatar
Post
MNFord, do you have a spray-in bedliner? There were some links earlier regarding some liner getting in between the gate and the bed causing tension that prevented the gate from unlatching smoothly.
Old Sep 6, 2000 | 01:17 PM
Jay911's Avatar
Lightbulb
I have the tailgate-sticking problem on my 97 F150 supercab. Take a look at the Nader pins that the tailgate locks into.. on mine, the one on the right side had the plastic collar around the pin shredded all to bits. I turned it around so the shredded part faced forward and the good part contacted the latch, and it worked OK until it worked its way around rearward again. I'm figuring replacing the pin (and plastic collar) will fix the sticky tailgate problem.
--jay.
Old Sep 9, 2000 | 03:56 PM
98SCREAMER's Avatar
From: Houston, by way of every major city in America.
Cool
I love my Snuglid, I always remember to
lock it and you can't open the tailgate unless you open the lid. On another subject,,,Go check to see if your spare is
still there!! someone tried to swipe mine
last night.....Thank heavens I was backed in over a curb,they couldn't get it
low enough to get the hanger loose.
98 F-150 4.6 Litre XLT2wd Ext. cab
prarie tan/tan int.
K/N gen.II fipk
custom dual exh/gibson rectangle tips
color matched snuglid
Superchip!!!
Westin nerfs blk powdercoat
Cobra 75WXST cb w/weather alert
Kenwood cd w/RS speakers,don't laugh it sounds pretty good
On the way/wheels,tires,air dam, etc..etc.......
doin the monochromatic boogie
on the front end.Billet grilles on order
