1st Door Cracks!! Now This!?!? Please Read & Reply!!!
Old Aug 20, 2000 | 09:44 PM
cigarxtc's Avatar
Exclamation 1st Door Cracks!! Now This!?!? Please Read & Reply!!!
Hey All you door crack F150 owners~
While I was waxing my truck & smokin crack today, I noticed some strange paint cracks on my roof!(Jus kiddin about the smokin crack by the way for any **** retentive people) Anyway, I was waxing the roof and noticed long cracks thru the paint of the rain gutter channels on top of my roof. The cracks appear to go thru the paint, from the rear of the channel all the way to the front of the channel on both sides of my truck on both sides of each channel. The best way for you to understand what I'm talking about might be to get in your truck bed and take a close look at your rain gutter sections. Mine are about 2 or 3 inches in from the sides. I dont know if those are metal stress cracks or just paint cracks! Either way, it should not be happening!!! Any feedback from fellow F150 owners who also happen to be paint and body experts would definately be appreciated!!! Please, everyone tell me what you think and if you find it on your trucks also?!?! I wonder if there is another metal stress crack happening besides the door cracks!?!?
97 F150 Reg Cab Short Bed
4.2L Auto
Current Performance mods=
Bosch Platinum Plugs
K&N Air Filter(Modified Stock Airbox)
Flowmaster 40 Single in/out.
My other Ford is an in the works 1950 F1.
Old Aug 20, 2000 | 10:40 PM
2000 F150 4x4's Avatar
Post
I think this is a know problem for these trucks. Do a search for old threads.
Old Aug 21, 2000 | 01:10 AM
Dennis's Avatar
Post
Yup. It's a problem that's almost as old as the door crack. I recall that there's a fix for it. Check with your dealer about it.
I'm on my second late model F-150 and have not experienced either the rain gutter or door crack problems.
Old Aug 21, 2000 | 03:24 AM
lightningcrashz's Avatar
Post
I am in the same boat as dennis 2nd late model f150 no cracks anywhere
JET air filter
delta tool box
pumpin' stereo
class III reciever hitch
spray in bedliner
headlight&tailight covers
2000 black F150 4x4 sport v-6
lightningcrashz@hotmail.com
Old Aug 21, 2000 | 03:30 PM
Dustoff's Avatar
Post
Yep..my 98 had them.
It is evidently caused by thin areas of clearcoat. The factory did not apply enough in the channel gutter. A repaint and new clearcoat will solve this problem.
2000 F-150 XLT, 4x2, 5.4L Supercab, LEV, Superchip, Styleside, Black with silver two-tone, 3.55 rear, class III towing package with heavy duty cooling package, Heavy duty shocks, 4 wheel disk ABS, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, factory leather wrapped steering wheel, FORD bedliner, K&N air filter, mar-hyde rubberized undercoating, Modine climate filtration system, Bugflector II, Mobil 1 oil and filter, Build date 7/00
Old Aug 21, 2000 | 08:43 PM
cigarxtc's Avatar
Lightbulb
Thanks for the replies all! This problem was news to me. Next time I'll check the old threads for any problems I might find. Now it's off to the dealer to see if they will fix it??....Yeeehaawwww!!
4.2L Auto
Accel 9000Series Race Plug Wires
Old Aug 21, 2000 | 10:20 PM
hmustang's Avatar
Post
Well so far no carks in the doors or in the paint on the roof as of yet truck has 15,800+ and counting.
2000 F150 XLT Reg. cab
4.6 Triton Engine
4x2 3.55 rear end gear
sliding rear window
automatic keyless entry
white styleside short box
Old Aug 24, 2000 | 01:40 AM
stephen muscio's Avatar
Post
I have the same cracks, '98 12,350 miles. Run the entire lenght of the rain gutter on both sides.
Old Aug 24, 2000 | 09:39 AM
Spartan's Avatar
Post
Did anyone have the new paint/clearcoat put on to fix the cracks (did they come back)?
My truck has them, the former owner (thanks Tina!) put some sealer over them, so I haven't seen them getting worse.
97F150 XLT SC 4x4 Flairside 4.6 V8 5sp Dk Toreador Red, 3.55LS
ARE tonneau cover, p255/70rx16 tires (came w/235), Superchip
Pioneer CD w/4 Polk Speakers, skid plates
bed liner, side window deflectors, reese hitch, K&N air filter
40s-2chamber Flowmaster, Bosch +4 spark plugs, rustproofing
Better Built Stainless nerf bars
heavy duty shocks
Old Sep 1, 2000 | 02:53 PM
kmmon1's Avatar
Post
cigarXTC and spartan,
The cracks in the rain gutters are common it is not thin clear coat causing the problem. I the channel there is what they call"flexible seam sealer" It is made to be fexible because it is where two pieces of metal are welded together.THis seals that from leaking. What is happening is that it is flexing in the corners of rain channels and the paint is cracking. They can repaint it but they will appear again. Not a big worr thought. the seam sealer does not rust so you chould have no problems leaving it alone.
Old Sep 1, 2000 | 09:15 PM
Kenster's Avatar
Post
I noticed mine the day AFTER I drove it home last December. (1997 model) The dealer took care of it and did a great job. Not just paint. It needs the flex stuff in the channel dug out and taken down to bare metal, the flex stuff replaced, then painted and clear coated. They baked it in a nice long time. No problems since.
Old Sep 4, 2000 | 10:10 AM
dons's Avatar
Post
I have a 97 with cracks in the paint over the entire surface. I was told by a PPG rep that Ford used a water based primer and it never dried properly. The paint needs to be stripped and start over. Ford decline to help with the cost. Last Ford I buy.
Old Sep 4, 2000 | 04:13 PM
Kenster's Avatar
Post
Dons says:I have a 97 with cracks in the paint over the entire surface. I was told by a PPG rep that Ford used a water based primer and it never dried properly. The paint needs to be stripped and start over. Ford decline to help with the cost. Last Ford I buy.
_______________________________________
Did you take it to a different dealer? Are you out of warranty? If so, how long? My '97, bought December 99, had the cracks. The dealer did not hesitate to fix them. I was just ticked that they would not give a loaner while it was in the shop because I had only bought it two days earlier. They give loaners at the service department but not the body shop.
Old Sep 5, 2000 | 01:05 PM
Soulgiver's Avatar
Exclamation
My 27 day old F150 Super Crew 2001 has them too! DAMNIT!!!!!!!!!
Soulgiver, It's who I am.
2001 F150 SuperCrew
