mirror signal bulb out???? 01 Lightning
Old May 7, 2003 | 02:43 PM
Cobrakid's Avatar
hey guys,
I got the bulb for my driver's side mirror bulb..
...now how do I replace it.
I did a search and not much help.
My Ford dealer basically said pry the back cover off, if
that doesn't work, pry the mirror off....that sounds iffy.
...and I don't want to break anything.
How do I replace that dam signal bulb???????
thanks.
Chuck in DE
Old May 8, 2003 | 11:40 PM
harleyrules's Avatar
There are clips that hold the mirror cover on. In order to undo the clips you will need a screw driver and a flashlight. Tilt the mirror glass all the way down shine light behind pass glass and you will see 2 clips, carefully pry clip, now tilt mirror glass all the way up and you will see 2 more clips pry those and remove mirror cover. Turn socket, remove bulb and install ...
Hope that helps you.
Old May 9, 2003 | 08:17 AM
Cobrakid's Avatar
thanks alot, I'll attempt it this weekend....
Chuck from DE
