Door Closing
Closing the doors on my truck has been a continuous struggle without slamming them. When my rear sliding window is open, the doors close very easily. I don't put anything under the seats but I do have a couple of tool boxes behind the seats. Does anyone have this problem? I have the manual windows so the doors are lighter than powered ones. All my passengers never close the door right either then I have to go over unlock it and close it again. Just frustrated.
The cab is, to a certain extent, "air tight", and there's no place for the pressurized air to go. I usually crack a window open before closing all the doors.
I also let everyone else close their doors first since I know how much it takes to close the door.
1999 Lariat Super Cab, S.B. 5.4L, 3.55 LS
and everything but the leaky slider window.
Bright red w/ gold 2-tone, Leather Captain's Chairs
Mods: Duraliner bedliner, Bugflector II, Hide-a-hooks.
& a leeetle chrome tip on the exhaust.
well not sure if this will help you have no sig so.... i dont knowwhat year your truck is but... a co-worker here had the same problem on a 99 he took it to the dealer and they installed a larger door vent??? I think they open up a a hole. There are vents built in to allow for cab- preasure to equalize, it they are small they dont allow enough volume of air to escape fast enough hence your dor doesnt shut all the way.
*2000 blk xlt f150
*5.4 4x4 3.55 ls
*sc orp pkg
*tow pkg, 17 inch wheels
*herculiner,remote start
*flowmaster, air box mod
*bfg ko's A.R.E. cap
*sony 10 disc cd player
*k&n air filter
*superchip
* havoline synthetic oil
****mods to come*********
harley davison hitch reciver plug.
removing stock cab steps& installing westins.
*2000 blk xlt f150
*5.4 4x4 3.55 ls
*sc orp pkg
*k&n air filter
*superchip
Just leave your ac/heater control *** turned to the panel position. This works great everytime and is very easy to get use too! Capt.
Capt. America..,
1998 F-150 XLTSC...2WD.. . 4.10LS rear...auto E40D... 5.4L...Flairside... Ground effects... Billet Pedals... Billet Grill... Billet Brake lite... Oval Mirror... Bed rails... Bug Deflector... Wood Grain Kit...Fog lites... TPS...Velocity tube... K&N... ss Ford tag.,.Tinted Windows... overhead/floor consoles... Mood lights...Blue bulbs... Alarm...Radar...Dashmat... Fire/Ice rear window tint ...conspicuity reflectors... cd changer...mobil 1... Painted rear Drums... Helwing Sway Bar... Dual Exhaust... Halogen Back-up bulbs... clear corner lens...
Tail lens covers... Leather...Floor Mats... Seat covers...Tow Pkge...
Side window Louvers... Painted Brake calipers... Custom Captian America Paint Job...TRIPLE LED brake lights...Rain guards... Painted throttle body cover...sliding rear window...Superchip...Custom Gas cap holder...2" leveling shackels...Fox tail key chain...Clear turn signal bulbs..
Capt. America..,
There are cab vent panels located behind the plastic molding in the bottom rear corners of the cab. I've run my CB coax cable through the one behind the passenger's side. They have a rubber baffle mounted within the vent that allows excessive cabin pressure to escape, while resisting aspects of the outside environment.
These vents should allow you to close your doors with no air pressure resistance from inside the cab. You may want to crawl up underneath your truck and see if Ford actually placed baffles in the spot where I previously identified. Put your hand up between the bed and the cab and use a small pencil to push through the vent, if it penetrates you're OK, if not, you have a hermetically (sp?)sealed cabin.
-kindest regards
1999 F150 4x4, wedgewood blue, 5.4l auto, Manick brush guard, Duraliner, KC Hilites, surf rod holders, tinted windows, K&N air filter without airbox, Velocity air intake tube, Midas Performance muffler with dual pipes, toolbox, Uniden CB with whip and now, enjoying a new reprieve on life with a 2000 series 5.4L (swapped engine due to Piston Slap).
-kindest regards
Thanks. I knew about the vents in the back. I'll try them this weekend.
98 F150 NASCAR Edition
Covercraft low profile tonneau cover
Coming soon: Intake filter kit, NASCAR Goodyear tires, Wet okole seat covers, Bedrug
Vic, mine does the same thing. I have manual windows too. Since there is no motor and that extra wight from power windows, it takes more of a shuv to close them. I hate it too...
Ford vs Chevy
www.fordvschevy.com
Moderator: Road Kill, Mustang vs F-bodies
2000 White F-150 Sport 4.2L 5-speed,3.55 gears
MODS K&N, Flowmaster 40 series.
superstang97@yahoo.com
Ford vs Chevy
www.fordvschevy.com
