Door cracks
Old Dec 5, 1999 | 10:50 AM
Steve g's Avatar
Talking Door cracks
i have a 2000 the door seems to have a slight bend where the cracks is at on other doors, two guy at work just bought used 97's i went to look at the door i was not liked on friday after i showed them the crack they where bummed, but my door looks to be built different the 99's could it be that they have modifyied the door ???? I hope i dont get the crack!!!! Looking to hear from other 2000 owners out there.
2000 f150 4x4 offroad pkg, 5.4 xlt
Old Dec 5, 1999 | 07:33 PM
Offroader1999's Avatar
Post
Were both of there doors cracked
99 F150 xlt s/c orp auto 5.4 soft tonneau, rubber maid bed mat,mud from the dirt bike(YZ250)
Old Dec 6, 1999 | 08:17 AM
Steve g's Avatar
Smile
No only the drivers side but one door is enough, they both had reg cab, mine is a ext cab , do more reg cab crack than the ext cab with the extra doors?
Old Dec 6, 1999 | 10:11 PM
Post
They seem to all crack about the same whether its an s/c or reg. There are 3 ford dealers around my area. I went to all to ck out the used trucks for cracks 18 of 23 were cracked. Some up to 1/2inch.
Old Dec 10, 1999 | 08:56 AM
theHedge's Avatar
Question
So I purchase a used 97 F250 XCab about a month ago because the truck had low miles on it (23K), it was in great shape and the price was right. Feeling real good about the truck and start reading these forums.
Last night, I went out and checked and I have the door cracks on both sides and have already experienced the door ajar syndrome. I haven't heard the piston slap yet but I'll keep listening.
Now the question, given that the original warranty is going to run out on time first before miles, what do I need to do now to make sure that I can have the door cracks fixed, the door ajar problem cured, ... while I'm still under warranty? Also since I didn't buy it from a Ford Dealership but instead from a Chevy Dealership, do I need to go to a Ford Dealership to have the fixes made? Does anyone have copies of the applicable TSBs (or TSB Numbers) so I can carry them along with me. I can picture it now, I talk to the Service Guy and tell him that the door ajar stays on sometimes (but is working now), the doors have cracks in them (but they just look like scratches), ....
Old Dec 10, 1999 | 10:11 AM
Fritzthecat's Avatar
Lightbulb
You are correct, on my 2000 I can see a bent/curve/stress (?) area where all the cracks start. On my friends 97 the same spot is just flat (well, beside the crack). Maybe Ford 'prestressed' the door skins now? I also get zero flex when running the windows up and down. There is still some movement when I slam the door shut though. I'll keep an eye on it for the next few years.
2000 F150 XLT 4x2 ExtCab Styleside 4.6 Auto in Island Blue
Superchip, K&N & Airbox Mod, LeBra soft tonneau and bugshield
Old Dec 10, 1999 | 07:29 PM
Sycoholic's Avatar
Cool
You need to go to a Ford Dealer to get any problems fixed under warranty. I don't have the TSB numbers on me, but if you look under older topics I have posted them.
Old Dec 11, 1999 | 02:57 AM
franks&beans
Guest
Posts: n/a
Cool
Have the dealer look up the "Special Service Message 13238". It deals directly w/ the door crack.
98 F-150,4.2L auto, 4.10 gears w/ LS, Tow Pkg. BFG AT 265/75/16, K&N air filter, Dynomax muffler, Edelbrock shocks, Hellwig sway bar
[This message has been edited by franks&beans (edited 12-11-1999).]
Old Dec 11, 1999 | 06:59 PM
JPD's Avatar
JPD
Post
Well I went to the local Ford dealership the other evening and out of about 20 s/c ranging from '97 to 99 I'd say 15 had door cracks. None on the passenger side so I am assuming the passenger door metal must be created out of a different die. They had 3 '00 model s/c trucks but none had cracks. I plan on buying a new truck next fall so I hope Ford has this fixed. Since the hwy dept uses every known chemical to keep the snow/ice off the roads in winter here in Wisconsin any exposed metal would probably guarantee me a rusty door in a heartbeat. If this problem isn't remedied then I guess it's hello Toyota Tundra. But I would rather have a Ford.
JPD
Old Dec 15, 1999 | 11:43 PM
hutch7's Avatar
Post
Does anyone know what the Message (13238) says about the repair??? The dealer is about to weld my door cracks and if another method is desirable I'd like to know. Ford has been reluctant to let me see the Message. They say they can't find it!!!
Old Dec 16, 1999 | 03:14 PM
EXTINGUISHFIRE's Avatar
Post
I have 47,000 miles on my truck and just had my door crack fixed. I went to the dealer and showed them the crack and they said that they would fix it for $100 deductible since it was out of warranty. ($100 deductible will fix anything on truck after warranty is up to a certain point if it is a manufacturer defect.) Later on that day I took him a print out of the door crack article on the bottom of the F-150 online homepage. He then said he will check on some more and get back to me. The next day the body shop guy called and said to bring it in and they would do it at no charge. Well I got it done before they changed their mind and it looks great.
1998 F150 XLT Reg. Cab, STX, White, 4.2 v6, 4x2, K&N, 3.55, Manik grill gaurd, **** Cepek 100 watt driving lamps, Kenwood mask CD-player, drop hitch, Ford hitch insert, 16x8 Atlas rims w/ 285/75/16 BFG All-Terrains KO to be put on when I get the new retooled bullseye spindles
Old Dec 16, 1999 | 08:59 PM
HCBPH's Avatar
Post
It can go either way here. Some had it repaired and had problems, others had it replaced and the same thing. Ford apparently reuses things like the weatherstripping, etc. If not taken off right, you have problems, air leaks, water leaks, no rock guard or clearcoat, plus it's the same door going on that cracked in the first place. I had mine repaired rather than replaced. Mine was welded, a stiffener plate made and glued in the door and patch painted. It came out super.
Good Luck
97 XLT Extended Cab 4X2, Northland Edition Short Box. Dark Toreador Red & Saddle Tan Accent. Tan Interior. 4.6L V8, 4-Spd Automatic. 3.55 Limited Slip differential, ABS, Factory Mag Wheels, Factory Bedliner, Non-Leaking Sliding Rear Window, Trailer Towing Package, LeBra Tonneau, Ziebarted, with Repaired Crack in the drivers door.
Old Dec 17, 1999 | 11:49 AM
White Knight's Avatar
Exclamation
THERE IS A FIX!!!!!
I just was called by my dealer and there is a reinforcement kit for this crack. They will fix it and put the kit inside. I pushed hard enough for a loaner car also. Everything is free.. my truck has 35500 miles and almost at 36,000 and they are covering it. FULL WARRANTY.
This is in the ford computers so EVERY DEALER SHOULD KNOW about this. I SAW THE PRINTOUT AND EVERYTHING. Get your truck fixed now!
Fred Folkerts/Chicago IL
1997 Ford 150XLT Black
5.4 TRiTiON/4x4 Off Road
Old Dec 17, 1999 | 05:52 PM
Bob's F150's Avatar
Thumbs up
White Knight:
Do you, or can you get some part numbers or SSM/TSB numbers for us so we can order these kits. It would be GREATLY appreciated!!!!
I'd like to do my doors before they start!
THANKS!!!!!!!!!!!!!!!!
1999 F150 S.Cab 4x4
Northland Edition,5.4
Off road pkg. Fleetside
Black w/grey int.
Old Dec 18, 1999 | 02:22 AM
Dustoff's Avatar
Thumbs up
White Knight,
A TSB or additional info would be great! Are all 97-00 trucks to be fixed? I am not sure that the 2000's had the door problem corrected..so I want to get the kit before any cracks develop.
Thanks for the heads-up!!
2000 F-150 XLT, 4x2, 5.4L Supercab, Styleside, Black with silver two-tone, 3.55, class III towing package with heavy duty cooling package, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, Pendaliner bedliner, K&N air filter, rubberized undercoating, cabin filtration system, Bugflector II, 5W-30 Mobil 1, engine build 10/4/99
