Frozen windows
Every morning during the winter, both side windows are frozen closed. After an hour of driving with the heat on, the windows will break free. Any ideas how to prevent this?
'98 xlt supercab flareside 4.6 5sp
Maybe use a piece of cardboard on inside,its worth a try!!!!!
Lariat#1
1997 Red/Silver F150 Lariat Flareside 3 Dr. SC..... ORP & Tow Package, Complete Lariat Option Package ,{APPEARANCE} AVS Carbon Fiber Headlite Covers, Tail Lite Slots & Door Sill Protectors,Owens Fg. Step Boards, Tinted Windows,Ford 2-Piece Bra,20" Chrome Exhaust Tips,A.R.E Bed Cover Lid,Pendaliner Inner Tail Gate Protector,Zie-Bart Total Paint & Under Coating W/ Sounder Deadener Protection, #1 Ford Truck Plate under glass on Front Bumper,Custom made Ford Red Window Decals,Blue Tinted Rear Lic. Plate Protector,Blue Billet Valve Stem Caps, Ford Chrome Hitch Receiver Cover {PERFORMANCE} 4.6L WINDSOR Auto, 3.55LS, 4-Wheel ABS,Platinum 3 Spark Plugs,K&N Air Filter W/ modified stock MAF side air box,Custom Cold Air Chamber (Dam) to keep hot air from K&N Air Filter,Tornado Air Man.,WMS Velocity Tube,Dual Exhaust System W/Stock Muffler,Performance Fiction Carbon Metallic Z-Rated Disc Brake Pads,Goodyear Wrangler A/TS Tires,55 Watt Halogen(replacement) Reverse Lites, Pilot 55 watt Halogen (add-on) Reverse Lites on Hitch under truck,Driving Lamps upgraded to 55 Watt Cool Blue Halogen Bulbs,Driving Lamps(Foglites) work W/ High Beams On & Driving Lamps(Foglites) also work (ON or OFF) W/ Park Lamps On W/Switched Relay {AUDIO} Stock In-Dash Cass. W/6 Disc Changer & 4 Stock Speakers,Trenz Billet #3 Antenna {SECURITY} Ford Total Security System W/ Motion Alarm All on factory Key Fob,Ford Warning Decals on Windows,A.R.E Cover & Hood also wired to Alarm System This is LARIAT#1..... IN The Great State Of Indiana "Where more than corn grows in Indiana".........http://hometown.aol.com/terrylariat1...page/auto.html A Very Proud Member of ...www.f150online.com
Lariat#1------------------
With the weather you've been getting in NY lately, why would you want to open your windows?
You could try one of the many spray de-icers and spray the windows.
Paul...
99 F-150 XLT SC Sport, 4.6L, Auto, Captain Chairs, Class III Towing Package, 3.55 LS, Sliding Rear Window, White, 4X2, CD, Soft Factory Tonneau Cover, K&N Filter, WMS Velocity Tube, Line-X Spray on Bed Liner, Gibson Side Swept Cat Back System, F150online Decal...
More to come!
ptarnuzzer@megsinet.net
Paul...
More to come!
If you can cover the windows with a truck cover or something similar..you will keep the moisture off of the windows and they will not freeze shut.
The ice/snow melts during the day, seeps into every crack around your window and seal...then freezes at night. I experienced this all of the time after living in Wisconsin for 15 years.
I have a king size black sheet that I occassionaly drape over the cab at night (during freezing temperatures), which is large enough to cover the front windshield and both side windows. I have never had to scrape any windows or had frozen windows. Any frost or ice comes right off when I pull the cover off of the truck.
2000 F-150 XLT, 4x2, 5.4L Supercab, Styleside, Black with silver two-tone, 3.55, class III towing package with heavy duty cooling package, 4 wheel disk ABS, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, Pendaliner bedliner, K&N air filter, rubberized undercoating, cabin filtration system, Bugflector II, 5W-30 Mobil 1, engine build 10/4/99
hey gg98,
I had the same problem, first time it ever happened, nice to someone else from NY, lots of luck
Gino Tedesco, '99 XLT 5.4l, SUPERCHIPPED, 3" Gibson catback exhaust,4x4 S/C Flareside D.wedge bl/Dk.graph, factory sidesteps & Tonneau cover, Manik grlgaurd w/Piaa lights, 305/70-16 Goodyear Wrangler AT/S tires
