Installing the head unit?
Old Nov 27, 2002 | 02:25 AM
PhAtNaV's Avatar
Question Installing the head unit?
How hard is it to install a head unit on a Navigator/Expedition? this would be my first audio instal, but the guys at Car toys said it was pretty tough?
Any suggestions ??
JD
Old Nov 27, 2002 | 07:09 AM
Robdude30's Avatar
Post
I wouldn't think it would be very hard at all. Isn't your radio/AC surround pretty similar to the F150? If so, even with no experience, you should be able to change your HU out in a couple of hours if you take your time. Make sure you get the necessary wiring adapters and you should have no problems at all.
Old Nov 27, 2002 | 06:02 PM
hummin25's Avatar
Not hard at all, espiecally if your patient. And remember everything comes with directions.
0BIll
Old Nov 27, 2002 | 06:41 PM
Invalid_access's Avatar
I am getting a head unit for christmas. How do you get that front piece off that surrounds the cd player.
Old Nov 27, 2002 | 06:51 PM
SilverStreak02's Avatar
If your Navi/Expy is a 97-02, then installing a new head unit is actually very simple. All you need is the proper wiring harnes, dash board kit, and those little "U" shaped tools come in handy as well. The tools aren't needed however. I've used a modified hanger before. To get the piece that surrounds your HU off is actually pretty easy. All I do is grab it at the HVAC vents, and Pull. If you have an airbag that can be turned off (most likely you do) then all you have to do is unclip the plug and set the dash piece aside.
FYI - Be carefull when choosing a Dash Kit. I installed a stearo in my 97 F150 and te kit that the audio store gave me didn't fit cleanly. there were small gaps around the kit and the dash board piece.
Hope this helps. E-mail me if you need anything else.
Old Nov 27, 2002 | 09:49 PM
Don's Bolt's Avatar
This is the place to get the radio adaptor, and wire harness. Once you have these it is real easy.
http://www.scosche.com/scosche/
Old Nov 28, 2002 | 10:25 AM
Rugby3's Avatar
Do it yourself, there are plenty of places to buy the dash mount kits. It is the easiest part of upgrading your system. Save your self the $$$$$$.
