Bring on the power!!!!
Since many of you have installed amps in these trucks before, I was wondering if you could recommend a good spot to bring the +12V power into the cab. Is there a factory hole in the firewall that can be of use? Hopefully I won't have to tear apart the dash to get it through. I want to get at least an 8-guage cable, maybe even a 4.
There are several grommets in the firewall. I have mine run on drivers side, on my 97 there is a rubber plug with nothing going thru it, that's where mine runs through. Just find you one of those and make you a hole in there, try to keep it pretty snug. Maybe even dab a lil silacone if you wanna seal it off better.
Good luck and have fun....Toby
ran my through jamb...where the upper body meets the front right side panel....and i put wire loom and electrical tape around the wire to water proof it...DID NO DRILLING and it sounds great
That little door step panel thing on the passenger side. Pop off the kick panel, pop off the door jam thing, and you will see a rubbing seal, pop it out, drill a hole in it according to the guage of the wire, run it through, nice tight seal, no holes in the metal
What do you need with a 4 gauge wire.
I was told not to put a 4 gauge on any amp less than 1000 watts cause it didn't make a difference. Is this true.
well it depends on how long your cable is.
I'm running 2 gauge to a PG splitter and 4 gauge to my 3 amps.
if its just one amp and over 300 watts or so go 4 gauge.
*I was told not to put a 4 gauge on any amp less than 1000 watts cause it didn't make a difference. Is this true.*
and it might not make a difference but it won't melt..
and rember your ground wire MUST be as large as your power.
