System Questions
System Questions
First - does anyone know if the subbox.net box for flip up rear
seats will fit my 2002 without making any mods (e.g. raising the seat).
Second - does anyone know if 2 JL 10w6's will fit in this box (I
have looked at the specs of the sub and the box and on paper it
works however I know that the subbox.net specs are not true to size because if they were who would buy it when they have the specs and can just build it.)
Third - Is the JL 500/1 enough to power these subs (sub rms = 300 watts)
Fourth - I want to install JL XR570-CS components will the JL 300/4 be enough power for these speakers?
Fifth - Does anyone know where I can get a decent cap about 1 farad and not spend an arm and a leg for it?
Sixth - What is the best wiring kit out there for the money? (so far I have heard get monster cable because it has a silicon strip that runs down the center and reduces noise.)
That should cover all of the system oriented questions I have any help on this topic would be greatly appreciated. Thanks
1) the 10" subbox.net box fit my 2001...not sure on 2002, should be the same
2) Unsure, but the actal depth of the box inside is 5.5" (on mine, anyway)
3) the 500/1 is the perfect amp for these subs....although it requires running all 4 coils in parallel for a 1.5 ohm load. It should run fine, and is actually rated down to that load.
4) I have the 300/4 running two sets of the XR-570-CS's and they sound great, and play LOUD!!!
5) thezeb.com
6) monster makes great stuff as does stinger, which I used.
5) thezeb.com
