Help Asap!!!!!!
i might be wrong..but i think u can just leave the amp harness hanging and just use the other harness....i remember i had that same harness and i left it hanging..and my cd player works fine.....BUT i may be wrong
TELL ME HOW IT GOES
TELL ME HOW IT GOES
HA..i knew it would work..good job man...dont BLOW TOO MANY SPEAKERS...they suck to replace...and if u do have to replace...watch out for those back retaining clips...they are hell to get out..
Normally, when you add a aftermarket headunit in place of the OEM headunit w/ an amplifier, the OEM amp will have a HI-Low line converter in it. What that means is that no matter how much powerful your head unit is, the convertor will drop the level down to under 4 volts. Then the amp will power your speakers.
Summary: If you do not bypass the factory amp you will be restricted to the specs of the factory amp.
I hope that made sense
