Box For 2 10" In A Screw?????
Old Feb 7, 2002 | 01:56 PM
dsm327's Avatar
Does any one know where I can get a box that will hold 2 10" and fit under the seat. I have a '02 screw. Thanks for the help guys.
Old Feb 10, 2002 | 11:25 PM
screwfun's Avatar
No luck
I have seen a one 10" box and a 2 8" box. For $300 a local shop said they would make a 2 10" box ... but I do not think there will be enough volume (CU). Of course I only have the little Kenwood self powered unit now for base now.
Old Feb 11, 2002 | 12:39 PM
Crewl1's Avatar
dsm327-
a box for 1 ten fits pretty easily under the left side rear seat, but you'll need a sub with small box requirements.
If you can find 2 tens with really small box requirements you could probably get something made up that would fit but you would most likely have to take out the seats for installation then put them back in.
That would prevent you from lowering the rear seats if that matters to you. I've seen a few installs that put 2 tens in the rear panel, that may be a better way to go if you really want 2 tens.
Old Feb 12, 2002 | 03:16 PM
dsm327's Avatar
Thanks for the replys.
