Installing a second amp?
Old Apr 3, 2012 | 12:14 AM
aviduser's Avatar
I installed a stereo in my truck a few months ago.
As is I have all 4 door speakers running of my alpine cda-105. And a 12" mtx roadthunder running bridged off a pioneer gm 5400t.
I've never installed a second amp just for mid's before, but I can tell my door speakers aren't getting enough power.
I've installed lots of decks/amps/subs. But am not really into the technical side of things. Apparently the amp draws 380watts Max bridged.
I'm wanting to add a pioneer gm 6400f. Am I going to need a High output alternator/batt.?
Wouldn't be a prob, but I just dropped $350 on a motorcraft alternator a couple months ago. And the current battery is 1 year old.
Old Apr 3, 2012 | 03:17 PM
Gtullous's Avatar
i have 3 amps in my truck...i added a small kinetics battery in parallel with main battery but still have stock alternator...when i had the subs wired @ 1ohm my lights would dim alot on heavy bass...after i rewired subs for 4 ohms its much better....But...im sure a high-output alt. would not be a bad addition...Maybe look for a wrecked police car in junk yard...they should have higher output alts. on them...
Old Apr 3, 2012 | 09:59 PM
aviduser's Avatar
Ok, well I went and had a look at some local amps available. I may go with a kicker 200.4
It only puts out 25 watts rms, but as is with my deck at 18 watts rms I'm looking for a little more power.
I guess I'll get it wired up and see how my charging system handles it. Not a really demanding set up so I think it may be ok.
Thanks for the input.
Old Apr 7, 2012 | 01:09 AM
aviduser's Avatar
Well, took the plunge with an alpine MRP-F300. Took about 6 hours to run 16 ga. to all my doors. Then clean up all the wiring. Here's a few crappy pics, I'm happy with the end result.
