cb
Old Jan 18, 2010 | 11:28 AM
dsq3973's Avatar
Here is how I have mine mounted the only problem I have is I cant use the power point until I move the cb down a 1/2 inch.
Old Jan 18, 2010 | 12:14 PM
redphantom01's Avatar
Here is how I mounted mine
Old Jan 18, 2010 | 12:28 PM
XPerties's Avatar
Originally Posted by Fordtruckman88
Xperties can you give us instructions on how u installed ur cb?
I have mine hardwired to the battery for clean power and grounded of course. I had a single din headunit install kit that I took a drimmel to and cut out the little storage compartment:
Once that is cut out there is a big open cavity that the cb can fit in but there is no support so it will sag in the rear. I went to my local hardware store and got a medium size bookshelf bracket. When you are looking into the cavity you will see a metal bracket to your left that I bolted the "L" bookshelf bracket to so when the cb slides in it has some support.
That's about it.
Old Jan 21, 2010 | 01:55 PM
Fordtruckman88's Avatar
That's about it.
did you have to widen the front any to make the cb fit?
Old Jan 21, 2010 | 01:57 PM
XPerties's Avatar
Nope.
Old Jan 21, 2010 | 02:05 PM
awesome im gona do this next with my new cd player
