My Code Alarm SRT-9000 Saga...
My buddy helped me install this... this was his 4th Code alarm system on a Ford truck. And as I said earlier, we had KC's directions.
just gonna throw this in here. when i was helping zeruin install his compustar we ran into trouble on a spot because what KC's directions said and what he meant were two different things. that being said its not always gospel whats in those directions. hope you have better luck with code this time, id be just as angry as you are if it was me
Not anybody that I would trust. I'm fairly experienced with electronics. I've completely re-wired two boats (motor included on one) and they haven't burned to the ground.
My buddy helped me install this... this was his 4th Code alarm system on a Ford truck. And as I said earlier, we had KC's directions.just gonna throw this in here. when i was helping zeruin install his compustar we ran into trouble on a spot because what KC's directions said and what he meant were two different things. that being said its not always gospel whats in those directions. hope you have better luck with code this time, id be just as angry as you are if it was me
The incorrect TX/out of range problem is an internal problem to the unit... Which was the failure to #1 and 2... #3 occasionally does it, but it at least kinda works.
If they are all the same model, how do they all of the sudden need to see a positive trigger instead of negative trigger?
Beats me, but I've tried wiring it both ways and it doesn't work. Even confirmed the wiring change with Code.
I've got a SRT9000 as well and I've had constant problems with it. I've shipped off three or so remotes to Travis to get fixed or replaced. This summer I had another jut quit working on me and I don't know what to do at this point. I really really need an alarm system but I don't want to spend the cash on a new one and have it installed. I think I'm going to take it to a shop and see if they can figure out the problem.
After looking around last night for awhile I'm beginning to think that me taking it to a shop and paying to see if they can fix it wouldn't be worth it because I will have more problems with it at some point. Now I'm kinda leaning on getting a Viper 5701. I can pick it up for 170ish and have it installed. Viper is so reliable I know I won't have any problems with it.
Edit: I just called the shops around here and one of the wants 350 for the Clifford 3.3x, which is the same thing as a Viper 5701. At that price it would be stupid for me to order one and take it someone for an install.
Im losing faith rapidly in anything audiovox. Id check your warranty and see what they say about a no lemon policy. Also find out why your model is no longer on the website. Id be rasing holy hell until I got my money back.
