stock stereo power
Old Jul 17, 2000 | 03:46 AM
sarhog's Avatar
Question stock stereo power
What is the power rating for the stock "Premium CD" stereo in a 2000 F250 Superduty?
What power requirements or specs should I be looking for in aftermarket speakers for this truck with the stock head unit? Lastly, should I go with regular speakers, or component speakers?
Sarhog in Guam
2000 F250 SD SC Lariat V10
Old Jul 17, 2000 | 11:27 AM
dirt bike dave's Avatar
Post
I don't know about the power of the stock unit, but I would recommend component speakers. I got the Infinity Reference, which are rated at a wide range of 2 - 90 watts. I ran them of my stock head unit for a while and they sounded pretty good. Then I upgraded the HU (17 watts rms clarion) and they sounded better. Then added an amp and they sounded better still. In my experience, the biggest gain with the components is in the high ranges. If you go with 6.5" rounds in the front, you get a much wider selection of speakers (but install is slightly more trouble).
Old Jul 19, 2000 | 10:08 PM
LOCOSVT's Avatar
Post
I know the indash CD players are Visteon, but I haven't been able to find any web site for them. Crutchfield has a Visteon in-dash 6 CD changer that is rated at 4x20 peak, and that's likely the same for the other CD players:
http://www.crutchfield.com/cgi-bin/S...576CD6&o=M&a=0
The speakers I took out of my Lightning had 4 ohm, 25w on the back, so that would coincide with the CD players power output.
In back to back testing of the stock speakers with Pioneer TS-A6895s (6x8 coax), The Pioneers only showed an improvement in sound quality at higher volumes, and the Pioneers actually had less bass range. For efficiency and quality, you can't beat a component speaker system, but for the best results you will also need a small 4 channel amp.
Old Aug 3, 2000 | 11:41 PM
musterer's Avatar
Post
try www.visteon.com
or www.radiosandmore.com
for more info on factory systems from ford
made by visteon
