relocating factory changer
has anyone relocated the factory changer (mine is a single cab, behind passenger seat)? i would like to do so, to make room for 10s and have use of the center console. just wondering if this were a hard task, or could be done by an amateur. thanks for any info
White '98 4x4 ORP Single Cab stepside. 5.4
Mods: K&N air filter, Dual 2 chamber Flowmasters, Grizzly Double Bend Nerf bars, 285/75-16 BFG ATs on 16x8 AR Atlas wheels, custom pinstripes, delta toolbox, Bug deflector, Superchip, RF Punch 150a2 amp with 2 mtx 8s(soon to be 10s or 12s) Grizzly Oval Grille Guard w/2 KC 100w dayliters
I don't know how hard it would be to move all of the wiring. However I talked to a friend of mine that is a ford dealer and he said that they put a lot of changers in that useless pocket just to the drivers side of the back seat.
Hope this helps...
1998 F150 XLT, extended cab 3 door,Pacific Green, towing package, 4.6L V8, 3.55 LS,Lund deflector, K&N Air Filter, Diamond Plate Toolbox, Whistler Radar Dectector, Uniden Police Scanner, 29WX-ST Cobra CB Radio. A Clarion Security System with Keyless Entry,
Audio Mods
Kenwood KDC-6011 CD player/changer control head unit.
JL 10" sub-woofer
Fultron "Depth Charge" amp 200w max.
4, TR570-CX JL Audio Coaxial Speakers (factory location)
Go see my truck and my Grandfather's truck at <A HREF="http://www.geocities.com/Vienna/Strasse/1992" TARGET=_blank>
Http://www.geocities.com/Vienna/Strasse/1992
</A>
Hope this helps...
Audio Mods
JL 10" sub-woofer
</A>
JGG, don't think he has a back seat. As far as wires, should be just a ?6? pin cable. If you need to extend, just cut and solder extenstion cable in then heat shrink it. Or if you are a major amateur, you can butt splice, but make sure the crimps are tight and you tape them up. Hope this helps..
2000 F-150 XLT, Deep Wedgewood Blue/Silver,4.6L,3.55LS,Class III Tow, Keyless w/alarm, soft tonneau. Basically a Lariat w/o the Leather!
Mods:
Line-X Spray Bedliner,Clear Corners and Tails,Airaid Intake, Superchip (Whatta RUSH!), Borla Anniversary Edition CatBack,
Future Mods:
3 1/2" Lift (Fabtech)
Eaton Supercharger
Roll Pan w/ Hidden Hitch
teksec01@hotmail.com
http://www.geocities.com/teksec/
[This message has been edited by TekSec (edited 02-26-2000).]
Mods:
Future Mods:
Eaton Supercharger
Mongoose
I moved my changer from behind the seat to under the middle seat but i have the 60/40 seats I then had room for 2-10" subs behind seats. No big problem with the wiring factory wiring will reach under seat. Hope this helps
lightning,
that is exactly what I want to do, with the 60/40. , any details on what you did would be very helpful.
Checkout what Truckin4 did with his Superduty...pix of changer installed in bench seat...very nice job. http://albums.photopoint.com/j/Album...2943&a=1938754
[This message has been edited by Marv1 (edited 03-11-2000).]
