How to Install Rail DVD System
Old Jan 10, 2008 | 09:17 PM
pmason718's Avatar
Im looking at my window sticker now and I dont see where it says that I have it. What does the harness look like.
Old Jan 11, 2008 | 07:25 PM
mustangcj's Avatar
I don't know what it looks like. When I pulled the overhead console off I reached in the hole in the headliner and could feel the wiring harness plug. If I can find a flashlight I will go try to look at it.
Old Jan 11, 2008 | 11:46 PM
pmason718's Avatar
ok thanks
Old Jan 12, 2008 | 10:44 AM
Slate's Avatar
bench test dvd player
Does anyone know how to make the ford rail mount dvd player turn on without hooking it up in the truck. I have a 12 volt power supply and a harness. I cant make it work in the truck, if I can make it work out of the truck I can figure out a way to run it while installed. I need help.
Old Jan 13, 2008 | 09:19 PM
Slate's Avatar
i think......
ok.... hey guys I think I found what I need. Someone that can look up part numbers PLEASE HELP. I need to know if this thing will work for me.
http://www.pie.net/pie_store/shopexd.asp?id=650
The rail mount dvd players part number is 4L3J-10E947-AG.
IF someone can tell me if this will work for me I would really appreciate it.
Old Jan 14, 2008 | 12:15 AM
pmason718's Avatar
I was going to send you that link. Well not exactly that website but another one selling the same PIE. I was told that if you have the pre-wire package and you bought this item than it will work. To me its too much money to chance it so Im going to buy the Alpine PKG-RSE2 and paint it the same color as my overhead bin (flint grey). This site sells Ford factory color paint. From my understanding they have a contract with Ford
http://www.bryndana.com/
Let me know what you think.
Old Jan 14, 2008 | 09:52 AM
Slate's Avatar
I like the alpine unit. Im just not sure how it will look installed or how to install it with the overhead rails. I guess you could mount it to an overhead bin or something. that at least would make it mount to the rail.
I wouldnt worry about it matching your interior. to me it already has enough gray to come close to matching.
If you install it let me know how it comes out.
Old Jan 14, 2008 | 11:27 AM
pmason718's Avatar
I will do. It should be that difficult. I'm going to mount it between the railsystem the best I can than cover it with the trim that comes with it. The trim ring will need to be cut, in order to fit over the rails. The unit is all black. I know that their are some pics online with the sides being grey but that is not true. I called alpine on this issue. Go to crutchfield.com and you will see the actual pic of the unit. My headliner is grey so I would like for it too match.
Old Jan 16, 2008 | 11:57 PM
Sandog53's Avatar
Okay, I used to work with KC autosound. I did successfully add the DVD overhead without the harness. First thing is, you absolutely have to have the audiophile radio, this is the only radio that will talk to the dvd player on the can bus. Second thing I did was plugged in the dvd player in the overhead harness, and routed the plug to the drivers side sill plate like it says, now you will not have a plug to plug this harness into, so you have to cut the plug off and get creative. It will work. Here is the pin configuration on the harness. Hope this helps!
https://www.f150online.com/forums/sh...postid=1620065
Old Jan 17, 2008 | 10:02 AM
Slate's Avatar
Problem is I dont have the audiophile head unit nor do I have the wiring for the dvd player. So I have taken some "Alabama Engineering" and I aquired a wiring harness and I ran it from my radio up inside the trim and handle on the side of my windshield and up and through the ceiling under the headliner.
To make the thing work without the audiophile head unit I have ordered one of these
It should be here this weekend.
The reason I havent bought a audiophile HU is I have a shaker 1000 in the truck and I am gonna do everything I can to try and keep it. Swapping out the HU is the very last option.
Old Jan 17, 2008 | 10:06 AM
pmason718's Avatar
Sounds good. Once your let let me know what I need to buy and where I can get it. I would love to make this work with the Pioneer Z2 head unit. If not Im going to purchase the Alpine PKG-RSE2 and paint it Light Flint (the same color as the headliner).
Old Jan 17, 2008 | 10:24 AM
6868vfco's Avatar
Rail player
Brandimotion the best option
