CB Help needed...
Old Dec 16, 2006 | 12:17 PM
Zaairman's Avatar
CB Help needed...
The other day I when I keyed up to talk, I could hear myself on my subs I still can transmit and receive fine, SWR is normal too... The CB is grounded to the radio ground, while the subs are grounded to a separate spot...any ideas?
Old Dec 16, 2006 | 12:29 PM
boomerkj's Avatar
sounds like feedback, sometimes a noise suppressor will help I have the same problem in my Mack tri-axle every once in a while
Old Dec 16, 2006 | 12:39 PM
boomerkj's Avatar
by chance were you on a FM station when this happened?
That is usually when mine does it on weaker FM stations
Old Dec 16, 2006 | 12:58 PM
Zaairman's Avatar
No, I was listening to a CD (actually it was a MP3-DVD). And it's ONLY the subs that it transmits over...
Old Dec 16, 2006 | 03:49 PM
arrbilly's Avatar
make sure your cb and your cb antenna cable are as far away from your stereo and rca patch cords as possible...
regards
Old Dec 16, 2006 | 11:36 PM
Zaairman's Avatar
CB coax is run down the left side of the truck, and the RCA's are on the right hand side.
Old Dec 18, 2006 | 12:15 PM
WaWaTuSi's Avatar
"The CB is grounded to the radio ground"
That is where I would start.
NExt keep power and ground away from all radio wires.
Dont share grounds.
What kind of CB is it? Some have **** poor filters.
Running an amp for the CB?>
Old Dec 18, 2006 | 12:55 PM
Zaairman's Avatar
Dont share grounds.
Thanks WaWa... and it's a Cobra 29 NW LTD, no amps.
Old Dec 22, 2006 | 12:19 PM
Frmboybuck's Avatar
Its not the cb, its doing its job. Its feedback from the stereo. Like WAWA said, start with seperate grounds and go from there
Old Dec 22, 2006 | 10:23 PM
dirtdobberoffrd's Avatar
hey man I have the same problem but it is when Im on fm stations and I have my box on thats norm tho
