CD Changer Cable Help
Old Oct 28, 2006 | 05:41 PM
MattsF150's Avatar
So my 00 Scab has a factory (6) disc in the console and I'm trying to figure out why it doesn't work. I pull it out today and there are no wires running to it. I pulled the radio and, if it's the upper, driver side receptacle [that is the same as the one in the changer] in the back of the radio, its got no wires going to it. So my question...where do I get that wiring harness? I checked Ebay and couldn't find one. Its a Clarion changer with factory Ford stereo. Obviously, the cheaper the better as I don't even know if the changer works. Is there a database out there where I could find harnesses that would be compatible in case I go to the junk yard?
Thanks,
matt
Old Oct 28, 2006 | 08:25 PM
themetermcse's Avatar
check out http://www.the12volt.com
they should be able to help you find one in no time. I think crutchfield also sells clarion so they should be able to help you find the cable as well.
Old Oct 29, 2006 | 07:56 AM
MattsF150's Avatar
Thanks for the reply. I didn't think about Crutchfield. I have an email into them now.
I'm also going to send Clarion an email directly and see what they have.
Thanks,
matt
Old Oct 30, 2006 | 06:14 AM
MattsF150's Avatar
Crutchfield didn't carry the cable.
Here's an idea. Is the connection in the back of the radio the same as the CD changer? The changer is a 12-pin (2 rows of 6). If so, I could purchase some cheap pigtails for doing an aftermarket install and put a length of wire in between them.
If someone knows off of the top of their heads, that would be great...if not, looks like I'll be pulling my radio.
Thanks,
matt
