Battery kept dying...
Old Jun 22, 2006 | 09:03 AM
JurassicBob's Avatar
I just hooked up my new system...a 600 watt amplifier, and component speakers. I was just testing the install out and while the music was playing the sound started to crackle and then it went dead. I had to jump the truck to start it. I then tried it again and it played for a few minutes...but when I tried to adjust the amps filter same thing happened again...
Anyone help with a diagnosis??
Old Jun 22, 2006 | 09:58 AM
polo2005's Avatar
when you are running an amp and speakers or subs, make sure that the engine is running or it will drain the battery, try a capacitor or a yellow top battery.
Old Jun 22, 2006 | 12:05 PM
Thanks... I'll keep that in mind.
I think I found out the cause though. I had the driver's side seat out and the two harnesses at the bottom were unplugged. The airbag light would stay on whenever I turned the key. Once I put the seat back in... everything worked normally. So... I guess it was because the seat was out??
Old Jun 22, 2006 | 02:17 PM
polo2005's Avatar
good thing that you found the problem
Old Jun 22, 2006 | 03:13 PM
You bet! I was really worried I was going to have to go back through the entire installation and look for problems.
Old Jun 22, 2006 | 11:01 PM
polo2005's Avatar
that would of sucked
Old Jun 22, 2006 | 11:09 PM
Zoomer7's Avatar
Same thing happened to me...
Had a system 'professionally' installed. Battery went dead in an hour.
Found out the tech had put a screw through a wire bundle that lay between the carpet and the floor when he screwed down the speaker box. Caused a short that messed up the amp and killed the battery.
Old Jun 22, 2006 | 11:24 PM
polo2005's Avatar
your lucky it didn't catch on fire
Old Jun 23, 2006 | 01:23 PM
chester8420's Avatar
Have you people noticed that a large percentage of folks that put sound systems into their trucks, burn their trucks up? I am a firefighter, and I'd say that probably 40-50% of our car fires comes from people putting amps and crap in their vehicles. If you're gonna do that, USE A FUSE! I would have burned up my Jeep several times if it weren't for fueses!
Old Jun 23, 2006 | 04:25 PM
Didn't know that... I have a fuse! Hopefully I won't become one of your statistics.
Old Jun 23, 2006 | 04:45 PM
frostby's Avatar
... and the other 50-60% is Cruise control ha ha ha!...oh geez, off topic.... somebody slap me...
