Installing Antenna on aluminum truck box
I have a 2006 FX4 with a DZ crossover toolbox bolted in using the J-hooks (not screwed in). I have a Wilson antenna on a mount bolted to the side of the box.
Anyone have any suggestions on the best way to ground the aluminum toolbox to lowere the CB/amature radio antennas SWR?
Thanks!
Thanks!
Two obvious choices:
-run a ground wire from the steel of the mount to a good ground under the bed (of course, if it's an aluminium bracket like most, you're screwed)
-get a ground plane antenna and cable similar to what is used on fiberglass boats. Since my flareside has a plastic (composite, whatever) bed, I used this and am very happy with reception and SWR. This type of antenna runs a ground wire within the cable and grounds the antenna directly to the radio. While *maybe* not as good a ground as metal grounding point at the ant. mount, I am getting 5-7 miles reception on a plain ol' Cobra 25
Thanks!
Thanks!
Aluminum conducts 60% as well as copper 80% as well as steel IIRC.... I have a wilson mirror mount drilled into the side of the box. Taking ga_cruiser's method do you think attatching one end to one of the bolts to the mount and the other to the frame do it or would I be better off grounding the Box seperate from the mount.
our beds are fiberglass? lol.... This is another idea but I already bought and wired everything up....
Thanks for the info.
