Fiberglass
Old Dec 6, 2005 | 08:31 PM
meangreenf150's Avatar
Fiberglass
Has anyone here made a fiberglass enclosure? im want to make one and i need some tips! I want to make a box for 2 10" subs that will fit between 2 bucket seats in a reg cab
Thanks!
Old Dec 6, 2005 | 09:07 PM
Squeakers's Avatar
What do you need to know??
Old Dec 7, 2005 | 05:06 PM
well i just need some tips on wat is the best way to go about this and how hard it would actually be. I dont kno if i need to build the base of the box out of mdf or wat to do. I just love the way that fiberglass boxes look and i want to make one so bad! So any info you have would probably help since i havent done this before.
thanks
Old Dec 7, 2005 | 06:05 PM
Squeakers's Avatar
Typically you would build the frame out of mdf. Then cover it with sweatshirt material, use a stapler to hold it to the mdf. Cover in resin. Then before the resin dries, cover it with t-shirt material. Again cover it with resin. Allow the resin to harden. Sand resin to smooth finish. You can use ICING its like bondo but much thinner. Sand, prime, paint. Just remember the better the sanding job the better the final finish. It is very time consuming to do this, good luck.
