Hook UP
Hook UP
Ok, here is the situation.
I have a 2004 Screw Lariat. My wife just bought a 2005 XLT Ford Escape. I took out the Audiophile system out of the Lariat and installed my own aftermarket stuff. I am curious to know how (If I can) to put the stock audiophile radio and sub/amp into the Escape. Which wiring harness would I need (if any) and how would I hook up the sub/amp to the system?
If you require any other info, please ask.
Thanks for any help/insight you all can offer.
Since your dealing with FORDS, it might just plug n play. It would be worth the time to pull out the Escape radio and take a look-see at the plug, there's a good chance its the same. You can always call the parts department of any FORD dealer and ask if the wire harness for each rig and see if its the same part #. Worth a try anyway. Good luck.
