6 disc
Old Mar 27, 2005 | 11:58 PM
dr408's Avatar
6 disc
i have a 00 lightning & the changer is behind the pass. seat.. what would i have to do to put a 03-04 lightning radio with the built in changer in or can it be done properly? thanx for any help
Old Mar 31, 2005 | 03:03 AM
dr408's Avatar
well, is any one gonna help me out,,
Old Mar 31, 2005 | 09:43 AM
heybeermantx's Avatar
I know that the radios from 99 F-150 and 02 F-150 are the same sizing, but with the added space of the 6 disc changer, you may run into space issues, just with the lower back portion of the radio. the best I can suggest is have someone measure their radio, then measure your space, and go from there.
Old Mar 31, 2005 | 10:25 AM
hawkfxr724's Avatar
Try this..
I'm totally ignorant on Lightning radios, but I have a 02 S-Crew which had the stock factory radio in it. I was able to install the 6 disk in-dash radio with no problems. Connectors matched and everything. Took about 10 minutes.
If it's the same, you'll need the little U-shaped tools to remove the stock radio. I got them at Advance Auto Parts for about $3.
You might want to try posting this in the Lightning forum as well. I bet those speed freaks could answer any question you have! Good luck.
