Reverse Detection Wire?
Old Jan 11, 2005 | 02:12 PM
tkljr's Avatar
I've found quite a bunch of info by searching the forms, but I haven't been able to find an answer to this:
I've ordered the Kenwood DDX7015 and DV4100 for my 2004 F150. I'm pretty sure I've identified where to connect everything except for the reverse detection wire. Can anyone point me to a fairly specific location preferably in the dash area?
Thanks....
Old Jan 11, 2005 | 03:03 PM
Mattmanyam's Avatar
If you can't find a schematic, pull a taillight, figure out which wire has 12V only when the reverse lights are on, the look for that wire under the sillplate up front. It may not be that simple, though, as usually the switch is on the tranny, you may have to run a wire to the rear. You might find it at the trailer connection as well...(or a provision for it...)
Matt
Old Jan 11, 2005 | 10:14 PM
pepatrick's Avatar
It is the Pink / black wire going down the right hand side of the truck.
I have AVN2454 and reverse camera. This wire is needed for reverse sense on the navigation.
Philip
