Speaker wire colors for 04 F150 Screw?
Old Nov 22, 2004 | 05:48 PM
SteveVFX4's Avatar
I tried to search on here but got conflicting results. Anyone know the Left Rear and Right Rear +/- speaker wire colors for the new F150 Supercrew?
Or is there a website where I can look this up for free?
I'm using the speaking level inputs on my MTX amp to run my sub (since I'm still using my factory headunit). I want to tap into the rear speaker wires for my input. I hope to find them along the door sill somewhere instead of having to remove my rear door panels. Will I be able to easily find them along the door sill, or should I go to the back of the head unit and tap in there?
thanks,
Steve
Old Nov 22, 2004 | 09:32 PM
erick_e's Avatar
This was taken from a previous thread here
Left Front (+) = Orange/Lt Green
Left Front (-) = Lt Blue/White
Right Front (+) = White/Lt Green
Right Front (-) = Dk Green/Orange
Left Rear (+) = White/Green
Left Rear (-) = Grey/Blue
Right Rear (+) = Black/White
Right Rear (-) = Brown/Pink
Old Nov 26, 2004 | 04:16 PM
papawoodie's Avatar
More Extensive list if needed (alarm or remote starter)
Function
Vehicle Color
Location
Start:
RED/BLUE
IGNITION SWITCH HARNESS*
Ignition #1:
BLUE/GREEN
Ignition #2:
N/A
Ignition #3:
N/A
Accessory:
BLACK/GREEN
Brake Light:
GREEN (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
TAN (ac)
ANY IGNITION COIL
Parking Lights:
BROWN (+)
HEADLIGHT SWITCH
Headlights:
RED/YELLOW (+)
HEADLIGHT SWITCH
Diesel Glow Plug:
N/A
Constant +12 Volts:
GREEN/VIOLET
IGNITION HARNESS
OEM Alarm Disarm:
PINK/ORANGE (+)
PASSANGER KICK PANEL
Dome Lights/Superv:
BLACK/BLUE (+)
HEADLIGHT SWITCH
OEM Horn:
BLUE (-)
STEERING COLUMN
Power Lock:
PINK/YELLOW (-)
DRIVERS KICK PANEL**
Power Unlock:
PINK/GREEN (-)
Trunk Release:
N/A
Alarm Input Wire:
BLACK/BLUE (+)
HEADLIGHT SWITCH
