Question
Old May 1, 2004 | 12:12 AM
Dizzead's Avatar
Question Question
Does ANYBODY know if it is possible to connect a stock 6 disc changer to a Kenwood CD headunit? A wire, harness, or some type of interface? I have a 2001 F150 XLT and Kenwood KDC-459.
The stereo has a CD changer in-port, but natrually Ford's stock CD changer's wiriring wont fit it.
Please let me know.
Old May 1, 2004 | 09:15 AM
cgorris's Avatar
Answer
In a word maybe. In more detail, there are companies that do in fact make adapters but it is to add a changer to a factory deck. If I remember correctly, Sony was the aftermarket changer that works with the Ford HU's if you use the adapter. I also believe (although I never tried it) that the adapters will work in either direction so you would possibly have to modify the plugs on the adapter. I will look to see if I can find an adapter for Ford to Kenwood. There are a few companies out there that make adapters for more than just one companies product. I will let you know in a minute what I find.
Old May 1, 2004 | 09:27 AM
cgorris's Avatar
Ok, I have confirmed that there are protocol converters that will interface Kenwood changers to factory HU. I am pretty sure that these will work in either direction but it would be best for you to check with PIE since they make the converters. I am not sure the cost on this so it may be more practical just to find a used Kenwood changer. Hopefully that helps you out.
Old May 1, 2004 | 10:10 AM
Dizzead's Avatar
Hey thanks. Ive been researching several sites similar to PIE and ive found the same thing..... Aftermarket changers to stock headunits, but not vice-versa.
Ive emailed them with my inquiry but strangley, no replies.
Ive got a buddy whom purchased a Mustang used, from a previous owner. He has a stock changer connected to an Alpine headunit, so Im certain it can be done, unfortunatley he wont let me disassemble his dash so I can see what brand converter was used.
Cant blame him but oh well, Ill keep looking
