Remote Lead and Relay Question
Old Mar 19, 2004 | 11:04 AM
2004Screw's Avatar
I understand what wires go where on a relay that controls multiple remote power leads but I have a few questions:
1) For the 12 v wire, you are suppose to use a fuse - what size fuse should you use? I have 2 amps that will be run from it. Total watts is 450 watts
2) Where do you tie in the 12 v wire? From the fuse box?
3) Where is a good place to put the relay in the new 2004 F150?
Any advise would greatly be appreciated.
Old Mar 20, 2004 | 08:15 AM
Sticker Steve's Avatar
1) 10-15 amps should be plenty.
2) I grab mine from the main power wire at the distibution block.
3) Mine is laying in the bottom of the dash under the HU.
Old Mar 20, 2004 | 08:55 AM
DonnyD's Avatar
Are you talking about the "remote turn-on wire" that sends a turn on sig to the amps from the head unit?
