in dash changer
Old Feb 6, 2004 | 07:20 PM
Stoner150's Avatar
in dash changer
will one of the newer in dash cd changers fit in my 1997 fi50, they look the same size and don't look like it would be hard to replace.
Old Feb 7, 2004 | 03:58 AM
svtlightning93's Avatar
As long as it has the 2 holes on each side for removal tools it should fit as they are the same size for all F150's 97 to 03. You might want to double check the harnesses. I can't recall if the early models have the same harness as an 03.
Old Feb 11, 2004 | 10:52 PM
BigDeal's Avatar
If it does fit into the mounting hardware in your dash you'll more than likely have to do some cutting on the inside of the dash structure to make enough room to side it all the way in. I had to perform this 'surgery' on my '01 SuperCrew when I did the swap to the CD-6 radio. But let me tell ya, it's been well worth the work I had to do to get it in the truck.
Here's a couple pics of the two radios side-by-side (CD-6 is in the background) and what my inner dash looked like post-surgery.
There's also some additional pics in my gallery if your interested.
Good luck.
-Mike-
Old Mar 8, 2004 | 11:04 PM
BostonCowboy's Avatar
Registered User
I have been scanning ebay for an indash changer to upgrade my single cd unit. There are a ton of them listed. Will any of these models work with my 03?
Old Mar 9, 2004 | 02:43 PM
BigDeal's Avatar
No. Not all CD-6 indash units are the same. To insure it will fit, make sure any radio you consider on Ebay (or elsewhere) came out of a '02 or '03 F-Series truck or Expedition.
-Mike-
Old Mar 25, 2004 | 10:29 PM
RCKCRSHR's Avatar
Will these 6 disc in dash
Ford OEM units work in my 1998 Ford F-150 SCab Lariat? Truck came with AM/FM cassettes and 6 disc cd changer. I know it will fit physically with some minor surgery. What about harnesses and such? Would I just need a later model harness/adapter cable? Any help appreciated. Thanks.........
Also, what is the difference between the 6 disc in dashers with the DSP and COMP buttons? Thanks.........
Old Mar 26, 2004 | 11:00 AM
Sticker Steve's Avatar
Yes it will fit with the above recomendations. You can buy the wire adapter for that year truck and one for that year HU to get the plugs you need. Check into Schoshe and metra.
DSP is Digital Signal Processor and COMP is CD compression. The DSP makes the sound come from all over the place and Compression is to help cancel road noise.
The 04 and up Hu's will not fit right in. They use a different mounting setup.
