cd changer stuck
Old Feb 2, 2004 | 01:13 AM
Stoner150's Avatar
cd changer stuck
on my cd changer the cartrige is stuck and won't come out, and it won't play cd's. i was wondering if anyone had the same problem, and what to do other than buying a new cd changer.
Old Feb 2, 2004 | 12:06 PM
cgorris's Avatar
Remove the CD changer, take it apart and then remove all CD's and magazine from it. It is possible that you have simply got a CD hung up and that clearing that jam will correct the problem.
Old Feb 2, 2004 | 06:20 PM
Stoner150's Avatar
how do you get the pannel off?
Old Feb 2, 2004 | 07:02 PM
cgorris's Avatar
Unfortunately I don't have a step by step instructions for doing this. You really have gotta wing it and figure it out on your own. Once you figure out how to remove the changer then you will be able to see there are some screws that will need to be removed from the sides of the changer and then the case will seperate into 2 pieces. Just be careful not to break anything. If you do not feel comfortable taking the changer apart then I would suggest that you take it to a reputable shop and have them remove the magazine and any CD's from it.
Old Feb 2, 2004 | 07:04 PM
cgorris's Avatar
Oh, once they or you get the CD's and magazine out then make sure you have all CD's out of the magazine before you put it back in the changer. This way you can see if the changer will at least eject the cartridge without having to go through the process of taking it apart again just to rescue your CD's.
Old Feb 2, 2004 | 08:11 PM
TexfordD's Avatar
Disconnect the power to it for a few minutes then power it back up...works on my Daughters all the time
Old Feb 3, 2004 | 03:48 PM
Stoner150's Avatar
i tried the power thing, didn't work, if i hit the cd button as soon as i turn the druck on it trys to find the cd or song but never does.
Old Feb 3, 2004 | 09:26 PM
cgorris's Avatar
Again, you probably have a CD jammed and my suggestion would be to take out the changer, remove all CD's to clear the transport. Once you have that done then try to apply power and a catridge with a single CD and see if it will play.
Old Feb 14, 2004 | 11:05 AM
punkdave69's Avatar
time for an upgrade...just a thought...
