Please Help
Old Aug 19, 2003 | 10:24 PM
Khlept0's Avatar
Please Help
I have a 2003 F150 and recently bought a aftermarket CD player. I made my first attempt at installing it and made a big mistake. I cut the plug from the wires. I now have everything I need to install the radio but I cant figure out what wires are what from the factory.
Old Aug 19, 2003 | 10:45 PM
gojo's Avatar
Oh OUCH!
I'm sure there are other's here who will be more help then myself but here's my 2 cents:
1) Hopefully you had the battery disconnected when you cut the wires, else you could have popped a fuse or worse
2) If I were you I would reconnect the factory plug that you cut out.
3) Once the factory plug is reconnected you should be able to attatch the aftermarket plug and install your new Stereo. I would recommend reading an install guide first, try this one:
Install Dr for F150
Good luck!
