Can't Remove factory radio
Old Jul 17, 2003 | 12:47 AM
99Whtlghtnng's Avatar
Angry Can't Remove factory radio
I have the keys required to remove the factory radio from mr 99 L but when I insert them in those holes on the sides of the radio and pull it just won't come out. what do I do?
Old Jul 17, 2003 | 06:31 AM
ViperGrendal's Avatar
You have to push out on the keys, that pushes the clips holding the radio in.
I posted this a couple days ago, here it is again. It explains how to pull the stock radio....
http://www.installdr.com/InstallDocs/FLM/PDF/356017.pdf
Old Jul 17, 2003 | 09:01 AM
Invalid_access's Avatar
Make sure you hear a click. Then push out toward the doors on the keys and pull toward you. It should slide right out.
Old Jul 17, 2003 | 01:27 PM
Robdude30's Avatar
Post
I had trouble the first time I tried it. I was pushing the keys in to far. Push them in just until you feel the click like Invalid_access said.
Old Jul 17, 2003 | 02:00 PM
Thank you for your advice I will try it out and see if it works
