subbox leaking air!
Old Jan 20, 2003 | 03:58 PM
recon_sct's Avatar
Registered User
subbox leaking air!
I took out my subs today to add some polyfill. when i put the subs back in the the boxs, air leaks out of the srew holes. i added a larger screw to one hole and that stop it from leaking. now another hole is leaking air. i tried putting in a larger screw and it didnt stop. anyone have an idea how to stop the leak.
thanks for the help
travis
Old Jan 20, 2003 | 05:49 PM
2Trucks1Wife's Avatar
Put some silicon on the screws and let it cure before playing the subs.
Old Jan 20, 2003 | 07:00 PM
Hazard269's Avatar
I would just put some latex over the screw holes and let that dry a little then screw the screw down. If air is leaking around the subs make a line of latex around the hole and let it dry a little and then screw down the sub.
Old Jan 20, 2003 | 11:14 PM
recon_sct's Avatar
Registered User
thanks for the info guys
i had to put the box back in the truck before i seen you guys had replyed. i have to take the box out again this week when i put in the brown bread from b-quiet. i will apply the silicon then, hope everything goes ok.
travis
Old Jan 25, 2003 | 03:34 PM
SpankDog's Avatar
Banned
I doubt its the screws leaking, you need to put a seal around the speaker, some foam weatherstripping works good. Nothing too fat, just get the small stuff. If you have carpet under where the speaker seals your going to have a hard time getting it to seal.
