Lifts and other
Lifts and other
I wantto make my truck as big as i can make it. I have a 1997 F150 REG. CAB 4X4 AND I AND WILLING TO PAY ANY PRICE FOR THE LIFT KIST AND TIRES. IM TRYING TO FIND A GOOD KIST AND A PLACE TO FIND ONE. ALSO IF I DIDNT PUT A LIFT KIT ON MY TRUCK HOW BIG OF TIRES CAN I PUT ON IT. COULD I PUT BLOCKS ON IT SO IT WILL RAISE THE SUSPENSION.
lifts
rancho makes good suspension lifts. body lift blocks give you no ground clearance....so if you're going for that that won't help you, but they will help you with bigger tires which get you more ground clearance. get the biggest suspension lift and a 3" body lift....you'll have plenty of room for big tires.
He's got a big lift and tires on it. Here's an address:
https://www.f150online.com/galleries...TOKEN=21963259
Bob
Bob
Re: Check out Whiplash's truck
Bob
Bob
As far as kits go, Id swing for a Superlift 8'' lift with the extended radius arms. The entire kit + arms will run about $1800 or so, and probably $400-600 to install if you have it professionally done. With a lift that size, Id stick with tires around 38''. That will give you the articulation you want while still having some monster *** tires. Stay away from the 44's and stuff, those are rediculous unless you live in a swamp.Good luck and be sure to post pics
