KC behind the grille
Old Dec 9, 2001 | 11:36 PM
Marv1's Avatar
Here's how I installed a couple of KC Daylighters behind the grille. I bought the angle iron from Lowe's and the KC's from Pep Boys...took a couple of days but I work slow (and cheap!)
Old Dec 10, 2001 | 09:51 AM
LakeSands's Avatar
That looks good. I am considering the same thing, either mounted to the fiberglass support or something like you did. How about the wiring and switch? My biggest concern is how to mount a switch in a new SCrew and have it look nice.
Old Dec 10, 2001 | 10:32 AM
Marv1's Avatar
Radio Shack Switches
Swap out the switch with one that you can get at Radio Shack for about 3 bocks. The switches are oval-shaped lighted rocker switches that will work perfectly with the KC wiring (or any other wiring for that matter). The oval shape really goes well with the Ford interior. I used the KC switch but plan to replace it with the Radio Shack one pretty soon. I mounted the switch on the plastic surround that is just below the speedo/guage opening and surrounds the top of the steering wheel column. Its easy to snap out, too.
I used a rotary tool on slow speed to open up a hole for the switch. I used the space just right of the column so I could see the switches from the driving position.
Old Dec 10, 2001 | 07:30 PM
Jupiterak's Avatar
Thumbs up
Nice job. That's what I used until I added two more lights (4 total). I later had to use a thicker angle iron.
Old Dec 11, 2001 | 01:47 PM
Fanatic's Avatar
Looks good!
Old Dec 11, 2001 | 10:33 PM
Dave Thibault's Avatar
i have a set of piaa 520s and i got them put the on the fiberglass piece. does anyone know if i can put a set of ks daylighters and the piaas behind the grill i was 4 lights.
Old Dec 12, 2001 | 12:18 AM
frog's Avatar
Thumbs up
I like the clean look. Good job. Now I have a project for my x-mas vacation.
Old Dec 16, 2001 | 01:41 PM
anyone?
Old Dec 16, 2001 | 02:32 PM
Jupiterak's Avatar
Yes. But you will have to reinforce the fiberglass crossmember with something to hold 4 lights. Or you can do like Marv1 and I did. I did originally had one set of 7" Piaa 80XT's and set of 6" KC's behind the grille. But later changed to 4 KC's and put the Piaa's in the airdam.
Old Dec 16, 2001 | 06:00 PM
LakeSands's Avatar
Nice looking truck Jupiterak. I think my next project will also be lights in the grill. Are daylighters the best fit for that space. That airdam looks great with the grill and headlights. Nice job!!!
Old Dec 17, 2001 | 10:47 PM
jupiterak where did you get that painted that thing looks tit. i likes alot. =o) I was thinkin of the lightning bumper though but that looks nice
Old Dec 17, 2001 | 11:16 PM
Jupiterak's Avatar
Thanks all. It's a Piaa airdam. They usually go for around $180-200.00. I later had a local autopaint shop paint it for $150.00.
Old Dec 18, 2001 | 10:20 AM
Marv1's Avatar
Sweeet!!
Jupiterak:
That's one great-looking truck you have. I like all of the various lights you have installed...I'll bet you don't have any trouble seeing at night. The OEM lights are so inadequate, but some additional lights may up for the deficient stock lighting.
Old Dec 18, 2001 | 01:49 PM
jupiterak do you have any problems with the paint chipping yet that was the only thing i was afraid of.
Old Dec 18, 2001 | 07:03 PM
Jupiterak's Avatar
I've had the airdam on for almost a year now and no problems at all. I made sure the paintshop did a good job painting this thing so it'll last through the winter. Especially with all the gravel they put on the roads in A.K.
