gt40 heads with what intake??
Im working on building the top end a little bit on my 95 351w efi.
I recently pulled the motor. I was at pick n pull the other day and came across some gt40 heads on a 96 explorer that I ended up buying..
I have a problem now..
the gt40 heads are internal egr so I would need to buy a new upper and lower internal.. I looked at the gt40 and the typhoon but noticed the throttle body on both come off on the passenger side on the manifold where mine comes off the front.. does anybody know of a intake setup that would work or did I just put my foot in my mouth? Took the heads into get the wholes drilled out to a half and the valve seals redone.. any advice helps thanks
