Efans on but strain on 110amp Alt!
With lights on at a stop, they pull down more so than what I remember when I had my 2000 Expy. Come to find out my '06 F150 has stock 110A alternator. Has anyone had issues or switched up to a 130A unit? I don't want to end up broke down out of town b/c of overworking my stock 110A unit.
Thanks,
Rob
Humble, TX
Thanks,
Rob
Humble, TX
I'm going to change the belt, maybe I'm getting some slippage. It has 91K on it and never been replaced. If that doesn't take care of it, then I'm going to get a 130A unit. The fans are actually a Dorman replacement kit for a 2001 Seville V8. There dual 15". Got it off Amazon for $115 new. Dual hayden controllers running through a another set of 50Amp relays to carry the load. Nothing fancy, but everything came under $200.
Thanks for the reply,
Rob
Rob
http://www.americantrucks.com/pa-per...ator-2539.html
Or
http://shop.mean-green.com/2008-05-F...54L-MG8252.htm
Or
I need to step up to a bigger alternator too, mines been really noisy since i put a big H.O. 15" fan on it. At one point with; AC, radio, lights, both fans on the voltage dropped on the dummy gauge real low
http://www.powerbastards.com/products.asp?cat=125818
Before I upgrade the alternator I am going to do the so called " Big 3/4 Upgrade" on the wires. I found it in the Tech Articles. I am also going to run a toggle to just keep 1 fan running during HVAC operation since we are not hitting 90s/100s down here in Houston.
Thanks,
Rob
Thanks,
Rob
found this one seems like a better option, i like that it actually puts the numbers on there, not just a vauge 300% figure
I had that 220 Amp alt on mine for about 6 months then began to have troubles. The amperage would 'jump' up and down enough to notice it in the lights at an even RPM range. It's sitting on my bench getting ready to send back. I will not be replacing it with another one because these alternators are controlled thru the PCM, I don't want to take the chance of messing that up. I am currently running the one '88 Racing' linked through American Trucks 130 amp unit and is doing very well so far
I had the under drive pulley on it.....either pulley, it did the same thing
