Fuel mileage help???
Old Apr 22, 2010 | 08:44 PM
  #31
hoser89's Avatar
Originally Posted by dbhost
INCLUDING not keeping the truck waxed. Lower air resistance means more MPG right? Slippery waxed surfaces help. Not a lot, but it all adds up... Not to mention your truck looks better when it is clean and waxed.
Not true, also proved on myth busters.. they put Clay all over the vehicle and had no change * 1 mile run
Old Apr 23, 2010 | 02:16 AM
  #32
timmypstyle's Avatar
Originally Posted by Titan357
5.4L XLT 6.5 bed, s-cab or is it s-crew? I have four doors, but not full doors, the front has to be open.
you have a supercab/scab. supercrew/screw is the full 4 doors.
Originally Posted by timmypstyle
heck this guy i work with has an 08 5.3L silverado 4x4 and just from getting bigger tires and wheels and getting a leveling kit, basically just a front end raise i think 2 inches, he dropped almost 3mpg. is only getting about 14.5 now. was getting about 17-18
he traded in for an HHR, gets double the mileage now but has half the cylinders.
Originally Posted by hoser89
Proven on the Tv show Mythbusters that tonneau covers DO NOT make it better.. It slightly adds drag, the beds are designed to create an air bubble where the air then flys over top of this bubble..
Plus I had a fiberglass one.. Added weight to the bed, added drag. Took it off, have never thought about putting it back on.
i thought the tonneau was the same as the bubble. the net was the only better one. but it doesnt make sense, a tonneau and the bed with a net on it would still have the downforce and probably the same amount and no air is getting trapped anywhere. in fact the bed exposed should make it less because of the wheel-wells blocking the air from escaping a little. i dont know.. plus they only used one truck and it was a shortbed. a longbed or ext cab or crew cab might make a difference
Old Apr 23, 2010 | 02:18 AM
  #33
that is why golf ***** have dimples, they help cut thru the wind. so go out there and get a sledgehammer and beat the crap out of your truck. you will get better mileage. just please dont try to do the windows
Old Apr 23, 2010 | 04:17 AM
  #34
wutecht's Avatar
you can always sell it and buy a honda
Old May 24, 2010 | 10:00 PM
  #35
JackedUp99's Avatar
Hell if we were smart, I bet those lil ol' smart cars could fit in the beds of our truck....just drive with your truck untill you feel good, then whip out that tinker toy and you can say your getting 30mpg with your truck! (untill you get smoked by that one guy that had to drive his f-150 farther and just creamed your A**)......Ok it was a thought but you never know!
P.S. : "Toyota- Moving Forward......even if you don't want to"
