troyer e-fans
Old Jul 21, 2009 | 03:47 AM
Stephen87's Avatar
troyer e-fans
I am planning on buying them but I was wondering would it hurt if I put the two e-fans that I currently have, in front of my condensor and behind my radiator(respectivly), both on my condensor and have them act as pullers to pull the air to the troyer fans, just to make sure that my compressor does not go out do to the pressure getting to high.
Old Jul 21, 2009 | 10:19 AM
grizzstang's Avatar
It sounds like massive overkill to me and the power drain when all 4 fans are turning would be intense. I also wonder if they would be fighting each other a bit even though they are moving the air in the same direction.
I have the Troyer fans (but I have not put them on yet) and everything I have read leads me to believe they are more than enough to keep everything cool.
Old Jul 21, 2009 | 06:17 PM
hivoltagefx4's Avatar
The 2 Troyer fans are more than enough. I had mine put on last week and they really cool the engine as well as make my A/C really cold now compared to the horrible cooling I had before being stock.
Old Jul 22, 2009 | 06:18 PM
Galaxy's Avatar
Concur. Lots of work for absolutely zero gain.
Old Jul 22, 2009 | 10:07 PM
Stephen87's Avatar
I see so I guess just the troyer fans, also apparently the fans I have now are only moving about 900 CFM each and the troyer moves about 6000ish CFM which is a heck of alot more, I can also go back to the stock thermostat and probably the truck will run slightly better
