tarus fans??
tarus fans??
anyone tried ford tarus fans for an efan swap?? there suppose to put out an amazing amount of cfm's, 2 speed, and pretty cheap at a PnP. you can either wire it up with relays of with a controler from these guys http://www.dccontrol.com/0820.htm and you dont even have to tap into the factory wireing, pretty simple intall and its still cheaper than most kits even if you buy the controler.
i may try this if i can find a couple a fans in the JY
yeah, i know about wiring them up, i was just wondering if anyone else had already used them. i know there about 15" wide, how wide are the 04-08 rad's? i guess i could go measure. hope its wide enough for 2
their a good size for a 2000ish year i dont think u need 2 of them, but if u do run 2 you will need 2 controlers because that fan pulls alot of amps. if you dont mind spending 500 bucks flex--lite makes a real nice kit for that truck, it's a twin fan set up pulling 5500 cfm's and it bolts right in, but it's pricey
$500, yeah....i mind. thats why im guaging these tarus fans. the fans pull about 50 amps at start, high setting 25-29 continuous. Low setting is 12-16 continuous. i think they put out about 2000 cfm on high. One may be enough, but two would be cooler
You do not have to scavenge junk yards and install used parts on your truck. New parts are still an option.
Try
# Dual 12" Fan 2600 CFM
# Low Profile
# Reversible, Quiet S-Blade Design
# Rubber seal
555-52116
JEGS Dual Electric Fans provide powerful cooling capabilities. These fans feature a one piece shroud constructed of glass filled nylon which provides strength and durability while keeping the unit lightweight.
52116 - JEGS Dual Electric Cooling Fans Details
Dual Electric Fans
# Features:low profile - 3.62" depth
# 2600 CFM
# 24.8 amp draw (12.4 per fan)
# 26"W x 15"H
# Reversible push/pull quiet S-blade design
# Rubber seal to eliminate vibration and increase air flow
# Includes fans, shroud and pigtails only
$189.99
# Temp-Control Fan Harness/Relay Kit200° On/185° Off for 195° thermostat
# For Dual Fan Applications
555-10571
Provide Continuous Voltage
to Prevent OE-Wire Drop-Off
Designed to utilize a manual on/off switch (sold separately) or to connect to an ignition switch for full-time operation when on, the Manual-Controlled Fan Harness & Relay Kit (#555-10559) includes:
# 30 amp relay
# Circuit breaker
# 48" of 10-18 gauge wire
# Assorted terminals and connectors
In two temperature ranges to accommodate engine thermostats, both Temperature-Controlled Fan Harness & Relay Kits (#555-10560 #555-10561, #555-10570 and #555-10571) may also use a manual on/off switch
or be used solely as a temperature-controlled switch.
Each kit includes:
# 30 amp relay
# Circuit breaker
# 48" of 12-18 gauge wire
# Temperature sensor with 3/8'' NPT Threads
# 3/8'' NPT to 1/2'' NPT adapter
# Available for Single or Dual Fan Systems
$69.99
Try
# Low Profile
# Rubber seal
555-52116
Dual Electric Fans
# 2600 CFM
# 26"W x 15"H
$189.99
555-10571
# 30 amp relay
# Circuit breaker
Each kit includes:
# 30 amp relay
# Circuit breaker
$69.99
If you want to go the junk yard route check out a Lincoln Mark VIII or mid 90's T-Bird fan. The shroud is quite a bit larger than the Taurus fan and the height is a good match for our truck radiators. They don't cover the width of the radiator so you would need to fab a shroud if you want it to cover the whole radiator. One of these with a DC Controls setup should cool an F150 nicely. I have one of these fans on my foxbody Mustang and it turned out really clean and works great so I picked up another one for the truck, but I haven't decided what to do for a shroud or controller yet.
used e fans
If you search electric fans on ebay there are quite a few out there all the relays and temp. switches as well. I thought the prices were very reasonable considering the fans would already be picked for you and shipped to your door. I also found people who fabricate custom aluminum shrouds. By contacting them they were willing to fab up whatever I thought I needed. I still havent committed to anything yet. when you do , please post some pics. It would really help me make up my mind.
500 a kit what are they plated in gold? just go to your local advance auto there like 70 each for 14inchers and they have the controlers for them there very easy to wire up a positive to bat , pos to ignition switched, pos to a/c clutch and a neg to chassis. has 2 pos wires out for fans. and the temp probe that pushes into your radiator coils. have had mine for 2 years no problems. temp is adjustable from 150 to 230deg.
these are pusher or puller fans they can go either way depends on where you want them. to push the air the blades face one direction to use as a puller fan you flip the blade. you can mount them on the radiator if you want on either side of it or on either side of the a/c condenser. it doesnt matter as long as it is pushing or pulling the air towards the engine.
