nitrous
Old Apr 7, 2009 | 01:58 AM
carlosc04's Avatar
nitrous
does any one here has nitrous on a 04-and up f150,..if so what brand,.!!?????
Old Apr 7, 2009 | 06:43 AM
FATHERFORD's Avatar
I had Nitrous outlet.
Old Apr 10, 2009 | 05:25 AM
phattacorider's Avatar
One of my buddies had ZEX. He got his kit from stylintrucks.com and it worked pretty nicely, +60hp wet system.
Old Apr 13, 2009 | 04:07 AM
carlosc04's Avatar
Iam thinking of adding a nitrous,..but dont know much of it,..how it works and all that,..is there a nitrous kit design for our trucks ,...like a direct fit,..or are they all the same,...the only thing I know is that Iam going for a wet shot,..only want a 75 shot..... can anyone help
Old Apr 13, 2009 | 10:05 AM
From what I understand (and I don't know a whole ton about them so anyone please feel free to correct me if I'm wrong), most kits are fairly universal between dry and wet systems as far as vehicular applications goes. Only thing is with our trucks since we run with electrically controlled throttles, there would have to be an arming switch mounted somewhere inside, then a button to "'inject" the N02 when you're going to use it. You'd also be safe getting a purge kit with it. Check out stylingtrucks.com, they have a kit on there along with many other accessories for trucks. The N02 kit is like $700 or something, adds between 50 - 60hp, can be tuned for greater, and isn't all that hard to install.
Old Apr 15, 2009 | 08:13 AM
FATHERFORD's Avatar
Horrible info in the last post...
If you want to be safe...
Electronic TPS Switch
Window Switch
Fuel Pressure Safety Switch
Purge
HTO Spark plugs gapped to 35
A fuel Block(NX and Zex make one there are two different versions, one with a 3/8" and another is a 1/2")
Tach Adapter
A WET nitrous kit. Single Nozzle, a NXL type system, or ballers do direct port.
AUTOMATIC Bottle Heater
NHRA Safety valve
NHRA Blow Off tube(if mounted in cab)
Now Go ahead and get a good all in one unit(such as FJO) add a wide band controller to it and have a damn near retard proof safe nitrous system.
I used the Trick Performance Gauges in my viper and LOVE them. Ofcourse they are nearly $400 a piece for both...
BTW I used to work with/for nx and one of the largest Nitrous Dealers in the world.... I know a thing or two about NAWZ!
Old May 5, 2009 | 06:44 AM
FATHERFORD's Avatar
Just realized you have a Saleen blower... Just up the boost and get a good tune. That blower will put out enough to chunk the rods out the side.
