. . . Mudder . . . help . . . !
Mudder,
Want to put one pair of KC lights on the front of my 2000 Scab to aid the high-beams, only used with the high-beams . . . which would you recommend? I don't have any partcurliar model in mind but I do lean toward the round type, but not set in stone . . . !
Thanks in advance!
Bob
Truck: 2000 F-150, 4x4, SCab, XLT, (imported from Canada) Island Blue, Dark Graphite 40/60 Cloth Seats (F/R), Styleside, 157” Wheelbase, 5.4L EFI, 4-Speed Auto O/D, AM/FM/CD, Class III Towing Package
Added: “Ex-Tang” Snapless Tonneau; Ford “Duraliner” Bedliner; “CDA” Paint Saver Pad; “Lund Runners” Truck Steps; “Husky” Splashguards; “Saddleman” Hood Protector; “WeatherTech” WeatherFlectors; 4th Brake Light (x 3!); “Pilot” Navigator 55 Watt Backup Lights; “K&N” FIPK; Lighted “Blue Oval” Logo - tailgate, “Weather Tech” Floor Mats (retired for the summer); Wheelskin EuroTone Steering Wheel Cover;
Wants: “Flowmaster” Force II Exhaust System; “Exotic Wood” Dash Kit; “RoadMaster” Active Suspension; Remote Starter; KC Driving Lights; Grill Guard (?); “Lund” Backdraft Tailgate Spoiler; “Superchip”; Remote Entry Keypad;
Thanks in advance!
Bob
Howdy. Go with the 150 watt KC Daylighters. I have ten of these and they are great, don't get much brighter than those.
Good luck.
98 Black F150 S/C 4x4 ORP 5.4
4" Rancho lift, 14 KC lights, lots of other goodies. Check out www.F150World.com/Mudder for pics and all the info.
Good luck.
The sealed beam or the Halogen ones?
2000 Extended Cab F-150
4X4 Offroad
Flairside Oxford White
AirRaid FIPK
2001 L Tails
2001 L 3rd Brake Light
2001 L Corners
Pioneer DEH8000
12 Disc Changer
Custom Amp Rack
Rockford Fosgate Punch 160
Rockford Fosgate 10" SUB
Keypad Mod
Polar Bear Brushguard
2 160 Watt K.C.'s, Duraliner Bed Liner
AVS hood deflector
AVS Vent Visors
4X4 Offroad
AirRaid FIPK
2001 L Tails
2001 L Corners
Pioneer DEH8000
12 Disc Changer
Custom Amp Rack
Keypad Mod
AVS hood deflector
AVS Vent Visors
The sealed beams, definately. I believe the halogens are only 100 Watt max.
Use a relay to power the lights from the battery. Use a dual pole dual throw switch to power the relay. Connect the relay to the center of the switch, then use the two inputs to power the switch. Use one off the hi-beam wire on the back of the light switch, and the other off a "switched" or "keyed" power source. This allows you to use them as a flash-to-pass, as well as not allowing you to forget and leave them on by mistake with the key off. The only way it's possible by accident is to leave the hi-beams and KCs on with the light switch, but the dinger will ding if that happens.
-Joe-
-Joe-
oops... forgot the sig...
98 Explorer (Lemon Law Case in Progress)
'00 F-150, X-cab, 4x4, Lariat, Off-road, Trailer Tow, Holandia Sunroof($1000), built 11/99 picked up 10/00!Clear Corners($36), Manik Stainless Steel 1-piece brush guard($700), Custom CB wiring, Uniden PC76-XLW CB radio($100) with K-40 Magna-Mount antenna (for now [$40]), 1 set of 165 watt KC Daylighters (for now... more on the way... $140) Fog Light Switch mod(free!!!), Custom switch mounting plate and overhead console, Bully Stainless Steel Trailer hitch drawbar w/ 2" stainless steel ball($80), Gray Tek Style Soft Tonneau Cover($250), Gray Line-X Bedliner ($450).
List of planned mods: Clear tails, torsion bar tweak, bug deflector, Chrome ORP rims.
93 Probe GT teal, OE rims painted to match, bone stock drivetrain, leaky exhaust.
Mudder, GIJoeCam,
Thanks for the information . . . I think I'll do all the wire looms in yellow to match the covers . . . !
Once again, the board has come through . . . not a big things to anyone else but me, but I do thank you guys for the info . . . !
I now intend to research everything I plan to do on the board . . . makes me feel that I don't have to do things alone . . . !
Thanks to all and have a really good one . . .
Bob
Truck: 2000 F-150, 4x4, SCab, XLT, (imported from Canada) . . .
Wants: . . . "KC" Daylighters . . .
[This message has been edited by swampview (edited 06-27-2001).]
Bob
