i need some help...
Old Mar 14, 2008 | 11:57 AM
F-1Fizzy's Avatar
Question i need some help...
lol...ok well i have my HID kit and with exception of finding a safe place to mount the balast..installing them in the FOG lights was a breeze...but now i need to install them in my headlights...the light kit i bought is a HI/LO beam light...its a single bulb that as an actuator that moves it up and down to create the hi/lo beam...now it needs to be plugged into the factory area or location were the current hi/lo beam thing is for the stock lights...but i dont quite no were it is...any help would be appreciated...pictures are always a plus....hope i explained this good enough for someone to no what im talkin about..lol...or do i need to buy a relay to plug into this? or is there a facotry one i remove to do so? i am very confused and not sure what has to get done
thanks
Old Mar 14, 2008 | 12:15 PM
F-1Fizzy's Avatar
i think i may have figured out my problem...i think i am just missing a relay...and that this plug doesnt plug in anywere...just a relay is supposed to plug into it..but i guess they never sent the relay with it...does this sound right? if so anyone no what size relay i would need?
Old Mar 14, 2008 | 02:04 PM
F-1Fizzy's Avatar
anyone?
Old Mar 14, 2008 | 04:32 PM
dlsipe1's Avatar
I have a hi/lo hid kit in my truck. There was a connector that plugged into the right headlight bulb socket and wires ran from there to a control box, then out to two separate ballasts. (the left factory headlight socket was simply sealed off.) There were connectors that ran then from the ballasts to each hid bulb(one for each side) it was pretty much plug in, mount the boxes, install the bulbs and go. Check your instruction sheet to see if you are, in fact, missing a connector. Good luck!
