Pulleys For 5.4L
Old Apr 16, 2001 | 10:00 PM
OneBadCrewX4's Avatar
Post Pulleys For 5.4L
I have a few questions about these. How much power can i expect? Who makes good ones?
2001 SuperCrew ORP 5.4L Gen I
MODS-Ramsey Brush Guard and Pro Plus 9000 winch, MAAP steps, Airaid, True Duals w/ 50 series muffs, Line-x, bugflector, and huskyliners.
http://albums.photopoint.com/j/AlbumIndex?u=1508480&a=11420452&f=0
Old Apr 16, 2001 | 10:18 PM
Neal's Avatar
Cool
HI!... ONEBADCREWX4 : I installed ASP power pulleys on my 5.4 truck and like them very much. I bought the 2 peice set. Crank/water pump pulleys. Stay away from the 3 peice sets if you can. You will run into charging problems with them sometimes. The 2 peice set is worth about 7-10H.P at the flywheel.You can purchace the ASP pulleys from ROGER LEMERE here online from the F-150 ONLINE STORE. Hope this helps you out.
NEAL " THE H.P FREAK" E-MAIL :nnewman@sympatico.ca
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP "FLIP-CHIP", BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, PERMA-COOL external tranny filter, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS, FORD RACING 24LB injectors, RUSSELL stainless steel braided tranny lines with fittings.
FUTURE MODS : BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150 LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 340H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.52E.T * MPH - 93.73 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 16.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon JAZ fuel cell,etc
Old Apr 17, 2001 | 04:29 PM
cyclone's Avatar
Post
Neal,
How complex is it to install the new pulleys yourself and how long can I expect to take?
Thanks in advance...
- Mark
2000 F-150 XLT Supercab, 5.4L, 4x4, 3.55 gears
  • Premium AM/FM Radio with CD
  • Polk DX7 Speakers (front), EX7 (rear)
  • Smittybuilt sure step bars
  • Ford (Duraliner) Bedliner
  • Class III Tow Package
  • Superchip
  • Ravin Z-55 SI/SO Exhaust
  • K&N Gen II FIPK
  • Eaglite Xenon 100/80w headlight bulbs
  • GE 9005 Halogen bulbs (fogs)
Old Apr 17, 2001 | 06:13 PM
Neal's Avatar
Cool
HI!... CYCLONE : It is very easy to do. You will need a crank pulley puller though. I did my entire install in about a 1/2 an hour.
