Fog Light Install
Old Mar 23, 2001 | 01:55 PM
5150PhD's Avatar
Question Fog Light Install
Hey guys..
Does anybody have any pictures or advice on installing some foglights? I want the switch to be near the parking/headlight switch.
Any information would be appreciated.
2000 2W F150 (Flareside Black ExCab) 5.4L (3.55LS) with K&N FIPK,Crazyabout150's JetChip *thanks*,Flowmaster Delta 40, Twin dual 3" pipes out the back, BioLight Xenon Lamps (cool blue), and Stock Ford Sport 17" Rims. Check out the site for spacers that I'm making and other install pictures. http://communities.msn.com/EnvironmentalDamageInc
Old Mar 24, 2001 | 01:31 PM
cooltrucks's Avatar
Post
5150PhD:
i have worte a techa article on how I installed my fog lights. you can check it out at http://www.geocities.com/Yosemite/Tr...htinstall.html
here is what my lights look like also. they are Pilot brand that i picked up at the local auto zone. The use 55w H3 bulbs.
Stock Stuff!
1999 XL, 2WD, standard cab, short bed, sport package, nascar package, bright red, V-6, 5 speed.
MODS.
Rockford Fosgate CD player
Pioneer 6x8
Class 3 hitch
fog lights
Black Rhino Lining
K&N filter
General Grabber ST tires size p245/70/R16
Uniden Pro510xl cb
Extang Tuff Tonno 3
***CUSTOM MADE TACH***
http://www.geocities.com/bassbuster/truck.html
For more info about my custom tach visit http://www.geocities.com/old_circuit/tach1.html
Old Mar 25, 2001 | 11:44 AM
5150PhD's Avatar
Post
Thanks cooltrucks....
That just where I'm going to install mine. I'm installing today, hopefully I'll have some pics for you.
Old Mar 26, 2001 | 02:12 PM
5150PhD's Avatar
Post
Freezer...
Yeah, I was given all the codes and regs from my older brother (Sac county sherrif). Plus I'm not the type to run with them on unless it's that dark or it's foggy, which happens alot in the central valley.
Thanks for the info, the install went fine, I'll post them to my website this week.
Old Mar 26, 2001 | 06:19 PM
hmustang's Avatar
Post
I've been thinking of putting some on mine for some time now just never get around to it but now that spring is here again I may be doing it shortly.
2000 F150 XLT Reg. cab
4.6 Triton Engine
4x2 3.55 rear end gear
sliding rear window
automatic keyless entry
white styleside short box
Old Mar 27, 2001 | 12:19 AM
Freezer's Avatar
Post
5150PhD, if you're going to do your own mount job instead of a factory type installation you may want to check the laws first. After I installed fog lights on my truck I visited the local CHP office to check the legality of driving with fog lights on. In California you can drive with fog lights on in any weather, but you cannot have both fog lights and high beams on at the same time.
But what you may want to check out, there are laws regarding mounting location. I think the law said that the fog lights must be mounted vertically in the same line as the head lights. The mounting location used by cooltrucks would be illegal in CA. So if you are concerned about getting a ticket because of an illegal installation, then visit your local CHP office and ask them. There are laws about mounting location, maximum intensity, and use with other lights on the vehicle.
P.S. If you are willing to spend several hundred, Ford sells a kit that includes a new lower bumper valance, factory fog lights, and wiring kit. That's what I did to get fog lights on my 4x2.
1999 Lariat SuperCab Flareside, Amazon Green with Silver trim, 5.4L, 4x2, 4 wheel disc/ABS, 3.55 limited slip, towing package, fog lamps, sliding rear window, captains chairs, keyless entry with alarm, spray-on bed liner, bug guard, and K&N. http://www.csc.calpoly.edu/~bfriesen/truck.html
Old Mar 28, 2001 | 04:16 PM
5150PhD's Avatar
Cool
Ok here they are....Blazer Driving/Fog Lamps (Projector style 55W)
You can check my website for the installation. Note: Ignore my instructions on headlamp install I didn't know about the two little tabs that make it easy..
Thanks for all your guys' input and info. It really made it easy.
Old Mar 28, 2001 | 08:01 PM
cooltrucks's Avatar
Post
The lights look good.
Where is it that they mount i was hard to tell in some of those pics.
Chuck
Old Mar 28, 2001 | 08:09 PM
5150PhD's Avatar
Post
Hey Cooltrucks
They mount on a flat spot that's part of the bumber section above the air dam. I used the flat bracket with sticky tape and made the bracket to allow the lamp to position properly. If you want more, I can try and take some better pictures.
Old Mar 28, 2001 | 09:58 PM
cooltrucks's Avatar
Post
you dont need to go take pics just for me.
i can see where you are saying they mount now.
Chuck
