9mm FMS Wires Installed
Old May 27, 2000 | 03:25 PM
BigRed2's Avatar
Thumbs up 9mm FMS Wires Installed
It was a damp cold day so I decided to install my new 9MM FMS plug wires. It wasn't as bad as I thought it would be. On the passengers side I pulled back the wire harness, oil filler cap, and PCV valve easy access to plug wires. The drivers side was more of a challenge, removed power steering pump bracket, the vacuum assembly and moved the speedo cables. Did it all in about 2½ hors taking my time and carefully routing one wire at a time.
The result is a much smoother idle and nice throttle response that complements all my other modifications. This will be my last engine mod for a long time, maybe my next move will be a Super Charger. Not till after my 36K mfg warranty is up though.
99' F-150 XLT 4.6L SC 4X4 ORP LS
- Ariad FIPK
- Superchip
- ASP Underdrive Pulleys
- Accel Coil Packs
- FMS 9MM Plug Wires
- Rapidflow 3" single CatBack exhaust
- Fluidyne Trany cooler
- A.R.E. Hard Tonue Cover
- Duraliner bed liner
- W Bucky Badger Hitch Cover
- Mobil1 5W-30
Old May 29, 2000 | 10:37 AM
jackhel's Avatar
Post
BigRed2
I have a couple of questions? How do you like the Accel Coil Packs and how much were they? Do you recommend the coil packs? The reason I am asking is because I think that is the only thing that I would like to do my engine, plus new wires and plugs of course (New heads wouldn't hurt either but too much money for the hp gain). I am just going to wait until I get all of them. It's going to be a pain to remove all of the parts you mentioned and plus the supercharger. Thanks
98 Nascar Edition
homepage http://www.freeyellow.com/members8/jackhel/index.html
POWERDYNE SUPERCHARGER, SUPERCHIP, AUTOMETER BOOST GAUGE AND POD, K&N FILTER, TRANSGO PERFORMANCE SHIFT KIT, DYNOMAX ULTRA FLOW EXHAUST, GUTTED MAF, 4.10 REAR END GEARS, XTRA BRITE HALOGEN LITES, AMSOIL Series 2000 Synthetic Motor Oil , 2 inch lowering shackles, G-Tech Pro Series II, AND SOME OTHER STUFF I CAN'T REMEMBER
Old May 30, 2000 | 10:43 AM
BigRed2's Avatar
Post
jackhel,
The coil packs where $105.00 per pair and only give a 11% increase over stock. For a Supercharger you would be better of with a DIS Ignition system(MSD or Jacobson) and the stock coils. The wires are nice and fit real well, they are 1000 ohms per ft resistance compared to the stock at 4000 - 6000 ohms per ft.
