Accel Ignition and MSD wires?
Old Apr 7, 2000 | 01:34 PM
jackhel's Avatar
Question Accel Ignition and MSD wires?
I was wondering guys if anyone knows about or has the Accel Super Coil. You can view the info at carparts.com. Any advantages or disadvantages. Also what is the cheapest price for a set of MSD spark plug wires. And the last question, Do you think the Poweraid
would help since I have the supercharger? Thanks guys, sorry for all the questions.
98 Nascar Edition
homepage http://www.freeyellow.com/members8/jackhel/index.html
POWERDYNE SUPERCHARGER, SUPERCHIP, AUTOMETER BOOST GAUGE AND POD, K&N FILTER, TRANSGO PERFORMANCE SHIFT KIT, DYNOMAX ULTRA FLOW EXHAUST, GUTTED MAF, 4.10 REAR END GEARS, XTRA BRITE HALOGEN LITES, AMSOIL Series 2000 Synthetic Motor Oil , G-Tech Pro Series II, AND SOME OTHER STUFF I CAN'T REMEMBER.
[This message has been edited by jackhel (edited 04-07-2000).]
Old Apr 8, 2000 | 11:06 AM
veloci's Avatar
Post
jackhel,
I bought a set of Ford 9mm wires for $85.00 and they are just great. My rough idle is almost all gone and the engine seems to be smoother. I do not think that MSD or ACCEL wires are worth the extra money. I do not know about the coil, i am researching that myself.
Black 99 xlt sc flairside,4.6 2w.d.,50 series flowmaster catback,
superchip,
RS9000 shocks,
3" lift procomp spindles,A/R Phyton 285/75/16 A/T B.F,
Ford 9mm sparkplug wires.
Snug Lid.2 KC daylighters.
FUTURE MODS: LS AND 4.10 GEARS.
Old Apr 8, 2000 | 10:25 PM
wolvrin704's Avatar
Post
Ahhhh, MSD wires. I know a little about the subject since I HAD them. They actually don't make them for our trucks. I ordered a set from Summitt and they sent me Mustang wires. I thought what the heck I'll try 'em. I will say that I noticed a difference in power; however, the things kept popping off on #3 and #4. So I finally went and got the Ford 9mm plug wires, they work just fine and look great in Ford blue. Also, the MSD wires were too short, by taking shortcuts you can get them too fit but a few of them were tight on getting them to reach.
97 F-150 S/C 4x4 ORP XLT 4.6 K&N , Flowmaster w/dual tailpipes, Bosch+4 plugs,Ford 9mm wires,Superchip.Patriot fiberglass toneau cover, Westin chrome step bars. Rear seat lift 4".
Kenwood 4011 stereo, Rockford 150a1 amp, Profile electronic crossover, 2 10" IDQ DVC's, and USAcoustics 2150 amp(on the way).
FUTURE STEREO MODS:
Memphis components in front, Pioneer 3ways in rear, amp for the components, and a cd changer.
FUTURE PERFORMANCE MODS:
4.10 gears, Edlebrock shocks, supercharger, Airaid, power pulleys.
Old Apr 9, 2000 | 10:57 AM
ps398's Avatar
Post
Accell does not make coils for the 97+ F-150 yet.
The ignition system does not have a distributor. There are 4 coils on the 4.6 and I belive the 5.4 has 1 for each cylinder.
Old Apr 9, 2000 | 11:23 AM
ROUSHFAN-1's Avatar
Lightbulb
2 coils on the 4.6
Old Apr 10, 2000 | 11:48 AM
BigRed2's Avatar
Post
I just installed the Accell #140018 coil packs, no major improvements noticed. However, I am still running stock wires but plan on going to Magnacore wires in the next month.
99' F-150 XLT SC 4X4 ORP LS 4.6L - K&N Air Filter & Custom 3" Intake from fender to TB, Superchip, PowerAid, ASP Pulleys, Rapidflow 3" single CatBack exhaust, Fluidyne Trany cooler, A.R.E. Cover, Duraliner bed liner & Mobil1 5W-30.
Old Apr 10, 2000 | 06:45 PM
ps398's Avatar
Post
BigRed, How do the new coil packs compare to the stock packs in output?
Old Apr 10, 2000 | 08:45 PM
BigRed2's Avatar
Post
ps398, here ya go !
NEW ACCEL PRODUCTS
FORD SUPER EDIS COIL
PACK FOR 1989-PRESENT
Re-engineered to be the only true performance Ford 4-tower style EDIS coil. Advanced section bobbin technol-ogy, highly specialized silicone magnetic steel core along with optimized winding, resistance, and turns ratio results in higher energy and voltage outputs and longer arc dura-tion.
Direct bolt-in, plug-in replacement. Compatible with Ford EDIS computer controlled ignition system as well as a Crane or MSD capacitive discharged DIS ignition systems.
Special high temperature epoxy resists shock and vibration, while increasing thermal conductivity. Secondary towers
molded in high dielectric strength “ACCEL Yellow”. Packaged as single unit; 4 cyls require 1 coil pack,“twinplug” 4 cyls require 2 coil packs and 8 cyls require 2 coil packs.
SPECIFICATIONS Tested with Ford EDIS system
Primary Resistance 0.5 Ohms
Turns Ratio 85 : 1
Secondary Resistance 11.6 k Ohms
Maximum Voltage 42,000 volts
Peak Increase in Energy vs. OE 11%
Peak Increase in Voltage vs. OE 8%
Peak Increase in Arc Duration vs. OE 7%
Peak Increase in Current vs. OE 9%
Ford Super EDIS Coil pack for 1989-Present 140018
Old Apr 10, 2000 | 09:02 PM
BigRed2's Avatar
Post
jackhel, put your money towards the new wires and an ignition system. Forget the PowerAid you have the power with your supercharger, I would put a little more fire in the hole. From what I have seen most SC cars/trucks go with a system like the MSD or Accel 300. Another trick is to use a smaller gap on your plugs with this type of set up. The Mustang guys go from a stock gap of 55 to a gap of 35 with superchargers.
99' F-150 XLT 4.6L SC 4X4 ORP LS
- K&N Air Filter
- Custom 3" air intake from fender to TB
- Superchip
- PowerAid TB Spacer
- ASP Underdrive Pulleys
- Accell Coil Packs
- Rapidflow 3" single CatBack exhaust
- Fluidyne Trany cooler
- A.R.E. Hard Tonue Cover
- Duraliner bed liner
- Mobil1 5W-30
Old Apr 17, 2000 | 03:44 PM
jackhel's Avatar
Question
BigRed2, I might sound stupid but it never hurts to ask? Why do the mustang guys go with the smaller gaps on their plugs with superchargers. Thanks.
98 Nascar Edition
POWERDYNE SUPERCHARGER, SUPERCHIP, AUTOMETER BOOST GAUGE AND POD, K&N FILTER, TRANSGO PERFORMANCE SHIFT KIT, DYNOMAX ULTRA FLOW EXHAUST, GUTTED MAF, 4.10 REAR END GEARS, HYPERTECH POWERSTAT, XTRA BRITE HALOGEN LITES, AMSOIL Series 2000 Synthetic Motor Oil , G-Tech Pro Series II, AND SOME OTHER STUFF I CAN'T REMEMBER.
Old Apr 17, 2000 | 06:02 PM
BigRed2's Avatar
Post
jackhel, here is what I was referring too from Musclestang.com. Their forums where a great resource until they took a dump at the beginning of the month. My guess is that with the increased pressure in the combustion chamber a smaller gap will ensure a good spark and combust all fuel/air in the chamber. One thing I don't know is if the Mustangs run the dual coil pack ignition like the Triton 4.6L. Some one had a thread under the engines section about this here on F-150 and it was the reason why you would want to use dual platinum plugs on the Triton 4.6L. The Mustang guys like to run NGK copper core plugs too, I don't know if that would be advisable with the Triton 4.6L.
This is a commonly asked question on the forums here at musclestang.
Generally, for modular engines, both Cobra and GT, for all years, the recommended setup is:
.054" for Naturally Aspirated engines (no NOS, Superchargers, or Turbos)
.032-035" for those running Power Adders
I will know more by June when I upgrade my plug wires and spark plugs.
- K&N Air Filter
- Custom air intake from fender to TB
- Superchip
- Accel Coil Packs
- Mobil1 5W-30
Old Apr 18, 2000 | 10:04 AM
jackhel's Avatar
Post
I just have one more question. All you guys who have changed your spark plugs and/or wires, how long did it take? I know mine is really going to be a pain especially since I have that supercharger in the way. Any special tips would be "greatly" appreciated.
98 Nascar Edition
