e-fan trouble shoot
e-fan trouble shoot
I'm sure there are plenty of threads on electric fans for '4 F150's, but didn't see 'em. Sooo, I am looking to throw on a dual set. I've seen running w/o a shroud & use 2x 12" fans
? I've got a 4.6L and I'm wondering if that set up will work (economical/functional) or will have to put out the big money & get a fan/shroud combo? Sorry if this is a repeat & I apprecciate any helpful input that ya'll may have!
B-Dub
? I've got a 4.6L and I'm wondering if that set up will work (economical/functional) or will have to put out the big money & get a fan/shroud combo? Sorry if this is a repeat & I apprecciate any helpful input that ya'll may have!B-Dub
I'm not exactly sure what you are asking...are you asking for a dual e-fan setup w/o shrouds?? Or are you asking for opinons on any and all e-fan setups?? Check out my sig...there are two links for my Troyer e-fan install..
Sorry I couldn't be more help..
R/
Craig
R/
Craig
It does work well with out the shroud, but there is no beating the FAL 270's, plus they work on 04+ f-150's too. Look deeper because alot of people on here have many different setups, so your choices aren't really limited.
Don't know exactly, but the FAL gives 5500 cfm's and is alot. It almost sucked my brothers cigarette through the grille. I would say under 3000 would do, but it will run for longer periods more often so...
Benefits I've noticed:
-quieter engine
-more hp's, just noticeable
-A/C runs colder
-better mpg's, again just noticeable
-quicker warm up
-more cool crap for the 4x4
-way more room in front of the engine for whatever, belt changes, supercharger assemblies etc.
-manual switch for extended cooling after shut off
I think it would be even more beneficial if you have a trailer your towing, let's face it every little bit helps.
-quieter engine
-A/C runs colder
-quicker warm up
