Benifets of E-Fans
Easy belt change...the oil filter can be reached from the top...cleaner, quieter engine compartment. I personnaly did not feel much of a HP gain (that doesn't mean it's not there)...but I'm looking forward to a bit better gas mileage.
I'm told that w/the pullies that the HP gains will be a bit more...I'm still trying to talk myself into getting them.
One other thing...If you like to work on your truck, installing these fans will give you hours of enjoyment..
R/
Craig
R/
Craig
E-Fans in conjunction with Pulleys will make a big difference. Check out the Chips forum and do a search on e-fans. And also call Mike Troyer for detailed benefits. I've been running both for nearly 5 years and it does make a difference in HP gains, mileage, etc. Remember, HP is turning the big fan clutch which has significant weight. Free this HP up and transfer it to the rear wheels.
